Results 1 to 10 of 23
Thread: Alarm not working
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Alarm not working
    I tested my standard vx car alarm today, and for some reason it does not work, when the alarm is activated the hazards come on but no audible warning ? i have checked the fuse and that seems ok, has any one else encounted this problem or is there a quick fix, thanks
    Feb 2007
    North west
    the siren is in the rear cubby holes on the laft hand side iirc, (from standing behind the car) check its connected. Its just a 12v siren, if its failed try Maplins or an alarm shop as most house alarms also run on 12v.
    Feb 2006
    north east
    cheers rob i have already checked that its connected, thanks for the advice on Maplins though
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by rob 2.2dti View Post
    Is it that easy? As you know the vectra alarm is a joke! I was always in the opinion that it was to hard to change cos of the canbus? If this is just a straight swap then I'm definitely up for this.
    Feb 2006
    north east
    i still have not fixed the problem, help still needed please.
    Jul 2006
    Mexico
    Quote Originally Posted by The Gas Man View Post
    Did you check the siren is getting it`s 12 v. when triggered?
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Quote Originally Posted by BlueRob View Post
    If it is a can bus alarm it doesnt get a 12v when triggered, i found this out when i fitted my add on Meta device to call my mobile when the alarm is triggered. I had to split the siren open and solder directly onto the siren wire inside as this did get 12v.
    Feb 2006
    north east
    im confused now? so what is the best course of action, the alarm is vx original so i presume it is fully canbus
    Jul 2006
    Colchester
    I would say to split the siren open, then plug it in and trigger the alarm and measure voltage at the actual siren inside (just red & black wire). Chances are its a knackered siren i reckon as your hazards flash.
    Jul 2006
    Mexico
    Thumbs up
    Quote Originally Posted by Maddog1974 View Post
    Interesting fact m8!
    Cheers!
  1. Alarm not working
    By Jamston39 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2013, 19:12
  2. my alarm sensor and interior light not working
    By nonpris in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 22:57
  3. Vec SRI, Keythob Not working: Setting Alarm Off
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2009, 14:15
  4. Alarm mod NOT working...Why?
    By BlueRob in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2008, 16:53
