Thread: Stickers
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    Default Stickers
    what is the best way to put the club stickers in my signum. do i wet the back or the whole thing, not sure (wot a plonker)
    any advice gratefully received
    Regular Member Jay Kay 313's Avatar
    Burgess Hill
    You don't need to wet anything, Make shore the serface is clean then just peel the backing off and place on the serface you want to stick to press down and make shore it's stuck then peel the front cover off, Job done
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    NIce job m8 which sticker will fit the 1/4 window on a vectra
    Thanks Steve
    Burgess Hill
    Thanks matey the small sticker will fit the 1/4 window hatch/saloon/estate & the Signum.
    You can get the bigger one to fit at the top of the rear window
    Regular Member Harry's Avatar
    Uxbridge, London
    i find it's alot easier to peel the backing off if you heat the whole thing up just a tiny bit, a minute over a gas burner just to loosen up the adhesive, or hit it with a hairdryer. you'll find that as you peel off the protective tape the vinyl will want to come away with it awell, warming it up just reduces it.
    Quote Originally Posted by Harry View Post
    Shouldn't be necessary on these stickers Harry. They used a strong adhesive on the backing tape, so the protective tape simply peels off without any letters trying to pull off with it. The ones you got on the Irmscher trip were from a different supplier and did have that problem - these new ones don't.
    To apply, simply line up where you want them to go and stick on one edge first, then rub along the width of the sticker to fully stick down. Then all you do is pull off the backing tape. A little tip here. Get a credit card and hold it flat against the sticker, then pull the backing tape off keeping the edge of the credit card at the point where the backing tape is lifting off, moving along as you peel off more of the tape - this will stop any letters being pulled off the glass and will also make sure the letters are totally flattened on the glass.
    That's it - job one. Stand back and admire.
    Nicking Ya Dinner.
    Wetting stickers is a good way to be able to play around with the positioning, well you wet the window actually then you can slide the sticker about until you think you have it level, then as D says use a credit card to withdraw air and water and get it pushed down firm before pulling the final backing off.
    That's definitely true for stickers along the lines of dealer stickers where it's one rectangular piece of vinyl - but these are individual letters (self-adhesive) so there really is no need for water. For lining up you just use the straight edge of the sticker and off you go.
    Jun 2007
    Sweden, Hjo
    just wondering. is it possible to order some stickers to sweden? .)
    Burgess Hill
    Can't see why not have a look in the www.vectra-c.com/shop
  1. Stickers
    By harley270906 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2010, 21:31
  2. Stickers!!
    By hibbsy18 in forum Styling
    Last Post: 24th February 2009, 14:44
