Thread: Tyre pressure for 19's
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Tyre pressure for 19's
    I had a bad spin at a round about in the wet the other day , i was not doing exessive speed, i was thinking may be my tyres are over inflated ? i have good tread all round with the two rear tyres brand new. Any other suggestions would be appreciated thanks
    VOTING UKIP IN AVELEY
    8 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    there are several threads on this ,seems 39f 35 r...is the standard....but some have 39 all round....if fully loaded then that changes ....best go read the threads and decide for yourself
    Regular Member rosssri's Avatar
    S.Lanarkshire
    I run mine at 37psi on the front and 34 psi at the rear anything over this i feel makes the steering over sensitive and increases road noise. I'm running 235/35/19 Toyo's T1-Rs
    Feb 2006
    north east
    so what could cause a spin in the wet ? any ideas , i have 3 kids and i would like to rule out all possible options for obvious reasons
    8 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    maybe someone had dropped some oil m8.......little bit of rain then its a skid pan
    Full Member Big Sig's Avatar
    As a general rule of thumb the pressure should be about twice the rim size. Apart from that try the handbook or have a search on here, its been covered loads
    Leicester
    Vauxhall's official figures for cars running 19" tyres are :-
    Engine Type :-
    Z18 XER
    Z20NET
    Z22YH
    Z19DT
    Z19DTH
    All should run 39psi front and 35psi rear for normal load.
    All should run 41psi front and 48psi rear for full load.
    Z28 NEL
    Z30 DT
    Both should run 42psi front and 38psi rear for normal load.
    All should run 45psi front and 51psi rear for full load.
    If you have well used tyres on the front and brand new ones on the back, this could explain why you spun. The rears may not have bedded in properly, and with the front well 'run in' can make the make twitchy.
  1. Alternate tyre size for 19's
    By 2.2 oil burner in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 19:03
  2. Tyre pressures on 19's?
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2011, 16:43
  3. tyre pressure.......?
    By david.aka.judas in forum Handling & Braking
    Last Post: 25th August 2009, 23:08
  4. What tyre pressure?
    By Padster72 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2008, 18:53
  5. Tyre pressures on 19's
    By gizmo10119 in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2006, 21:01
