Thread: cdti engine
    northampton
    Default cdti engine
    hi peeps,
    Though i would tap into the knowledge held here!
    I have 1.9 150 04 plate. I know the engines are not the quitest but on hard accerlation i have what can only be desribed as tappet noise. tick, tick tick, the sound gets quicker as i do! all so after a while sitting still with engine off (+4 hrs) i can get the noise whilst going along slowly..
    Any advise or expenrence of this problem?
    many thanks...
    Regular Member Eddie Dee's Avatar
    Feb 2007
    BELFAST
    Hi Im getting an irregular ticking noise on idle thinking seriously of taking it to the dealers to be checked.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    May sound daft but have you's checked the oil level. It may be needing topped up
    northampton
    Yep, all the so called "basics" have been done. Even had the hose pipe out to locate the noise but since the whole drive train is noisy it was difficult to locate. Saying that i can only notice the tapping sound when driving with the window down...
    S.Lanarkshire
    Dunno then mate a few of my work mates have commented on my engine sounding rattley but that's usually after a i've just started it up.Will be interested to know what dealer says.
    Regular Member videodoctor's Avatar
    Blackpool
    Just out of curiosity have you checked your tyres.There could be a stone or screw stuck in one of them causing the tapping sound.Obviously if it taps when standing still then its not that but worth bringing up.(i also had a tapping once from the front drivers wheel and it was 2 stones stuck in between the disc and the metal cover behind the disc)
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. V6 CDTi Engine Oil
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2012, 12:28
  3. cdti engine pic
    By jofenan in forum Engine & Drivetrain
    Last Post: 16th January 2011, 23:36
  4. What is the best engine oil for 1.9 cdti?
    By Nev in forum Engine & Drivetrain
    Last Post: 18th May 2009, 15:21
  5. 1.9 CDTI 150 Engine
    By Gavin in forum Engine & Drivetrain
    Last Post: 30th September 2005, 17:09
