Thread: VDA plug
    Southampton
    Default VDA plug
    Does anyone have any photos of where the VDA plug is if its installed, or could someone describe it in fool proof terms :-)
    I have a 55 signum (facelift) with cd70 navi and reading some other posts I was expecting to have one. So either I am missing it or I don't have one.
    I've removed the glovebox and had a look but don't see anything, should I be able to see it there or would I have to remove some more trim?
    Feb 2006
    Dorset
    Look to the right you will see a loom running down its normaly taped to that , and the FME terminated ariel cable should be there as well .
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Check here mate, may give you an idea
    http://forum.vectra-c.com/showthread.php?t=25372
    Southampton
    Thanks guys, looks like I don't have one, pulled the radio out and there is no mute wire going to the unit so I guess that confirms it.
    Oh well, gone and got a SOT-122 so I just have to work out whether to butcher it to get volume control through the radio & steering wheel, or to go the easy route and just plug it in :-)
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. preface gid screen plug, is it the same as the 32 pin vec b mid plug?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 23:15
  3. plug
    By titley1976 in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2011, 22:14
  4. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  5. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
