Results 1 to 10 of 15
Thread: Brake Calliper Help?
    Regular Member Digital_kid's Avatar
    Oct 2006
    Cheshire
    Default Brake Calliper Help?
    Hi I have a 2.2 SRI Vectra C on an 02 reg and its just failed its MOT on the offside rear calliper.
    Aparently the brake is ok but there is no handbrake working is this a new calliper or can I free it somehow?
    If its a new calliper anywhere I can get a cheap one?
    Feb 2007
    North west
    probably just seized, free it up with a rubber mallet, srtip it and use some copperslip grease. The moving calliper can stick, especially with salt from the road and if its not used for a while.
    Oct 2006
    Cheshire
    Thanks Rob,
    When I strip the caliper down is there 2 pistons one for the handbrake and one for the brake?
    Just so I know if I have it working as the brake is fine?
    L.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    not 100% but i believe its just one piston.. With the handbrake cable actuating the piston via the back of it. Mark GSi will know for sure though.
    Gonna run out and see wot i can see...
    edit: Not a lot i can see.. It does look like it actuates something internal to the caliper which then operates the piston
    Feb 2007
    North west
    yes 1 piston need to tap it from one side to the other to free it up. Easier with the caliper off the disk then you can see it move. Might just need a few taps.
    Ashington, Northumberland
    The handbrake and the service brake work the same caliper, therefore if it was a seized caliper it would effect both the handbrake and the service (foot) brake, ie they would both have low braking effort. Get somebody to sit in the car and work the h/brake on and off while you watch the operation of the cam lever on the back of the caliper (the bit that the cable connects to) I think you might find that the cable is either seized, snapped or stretched on that side. You could however have an internal fault with the cam in the caliper and this will be indicated by the cable operating the lever properly when you get your mate to work your handbrake. HTH
    Regular Member stickshift's Avatar
    North London
    I had exactly the same problem with mine and was also brought to my attention at MOT time but the examiner was a bit more sympathetic and let it go. I was in the process of looking for a new one when it suddenly started to work again! It's been as good as gold ever since. You might be lucky too but it might be as simple as winding the piston back and reseting the self adjuster.
    Here's a couple of links that might help.
    http://www.vectra-c.com/forum/showthread.php?t=10499
    http://www.vectra-c.com/forum/showth...just+handbrake
    Oct 2006
    Cheshire
    oo flip sounds like a common problem better keep some old aircraft chocs in the boot!
    I think i'll try the common, "yank the handbrake up a couple of times" trick if not ill take the caliper off mares well change the pads at the same time.
    Hey is there a clever way of telling if its working - jack it up and spin the wheel maybe?
    Thanks again lads,
    L.
    Oct 2006
    Cheshire
    ok took the wheel off this morning and the handbrake lever on the caliper had seized, give it an encouraging tap and now it moves.
    Heres the thing when it was jacked up and I tapped the arm closed the wheel spun (all good) when I pull the handbrake on the wheel locked (all good to!) but when I release the handbrake the wheel spins but there is slight resistance not much (is this right?) Just didnt want to drive along with the brake on!
    Also when I brake there is now a creaking spring type noise coming from the caliper should I spray the caliper with WD40 (just the arm bit)?
    Thanks again folks.
    L.
    slight resistance is to be expected, and yes, it is okay to oil the pivot lightly to free it, but use some spray grease to give it some long term protection against seizing again..
  1. red brake calliper paint set
    By The Gas Man in forum Parts for sale
    Last Post: 24th July 2010, 20:19
  2. yellow brake calliper brake set
    Last Post: 22nd July 2010, 22:41
  3. Rusty Brake Calliper
    By Geo77 in forum Suspension, Wheels & Brakes
    Last Post: 30th October 2009, 01:41
  4. Brake calliper Colour
    By bigmac in forum Styling
    Last Post: 6th February 2009, 01:47
  5. brake calliper tool
    By blackbeauty in forum Parts for sale
    Last Post: 28th June 2008, 15:14
