Thread: A quick tyre question please!
    Jun 2007
    Devon
    Default A quick tyre question please!
    I have a standard 3.0cdti signum with standard wheels and 215/50/17 /91w tyres on, will I be able to fit 225/50/17 onto the origional rim?
    Many thanks!
    Adam
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    this thread should answer any questions..
    http://forum.vectra-c.com/showthread...=225%2F50%2F17
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by Adamdavi3s View Post
    Many thanks!
    Adam
    There seems to be a lot of debate as to whether the 3.0 V6 CDTi should be fitted with Extra Load tyres (as it does from the factory). 91W are Standard load. Have a read of this: http://forum.vectra-c.com/showthread.php?t=25832
    Jun 2007
    Devon
    Hey,
    Cool thanks for the links guys.
    I'm going for some 225-45-17 rated at 98w (Pirelli pzero) so looks like they should be ok!
    Cheers!
    Wilts
    Hey,
    Cheers!
    Deffo be ok with them at 98W, not sure about 225/50's though. usually go for 225/45....
    There have been loads of threads on this very subject, might be worth a search....
    The "50" part is actually a percentage of the width I belive and is not an actual measurement in mm. Going for 225/50's would throw your speedo out too much. 225/45 keeps the diameter of the tyre as close to the original as possible.
    Feb 2007
    North west
    hes on 17's - isnt 50 the std ratio ?
    Wilts
    Not if you go to 225's it isnt. You have to drop the profile to 45's to keep a similar tyre diameter
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Quote Originally Posted by rob 2.2dti View Post
    The manual also states that 22/45/17 is the alternative tyre size
    Hey,
    Cheers!
    They should be fine. I believe you'd also be fine with 95 load rating on 17s. 225/50/17 is not a profile recommended by Vx, so best not to for insurance purposes. Also a 225/50 would have an even bigger sidewall than a 215/50 as the 50 is a percentage of the width of the tire - your handling would suffer a bit due to the larger sidewall. With 225/45 you'll find a much greater choice of tyres available and also a bit cheaper as it's a much more common size.
    HTH
    Jun 2007
    Devon
    hehe sorry I think peeps read by thread before I edited it!
    I will be going for 225-45, I called black tyres who suggested that changing the ratio would mean my car would spit the gearbox out the back as it was changing the rolling radius to much, so I had a little chuckle at that rather extreme response!!!
    I'll be ordering some 225-45's online later!
  1. Quick Tyre Question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 17:52
  2. Another quick tyre question
    By Vaux-Man-G in forum General Chat
    Last Post: 10th June 2009, 02:05
  3. Quick Tyre Question.....
    By Signum_CDTI in forum Handling & Braking
    Last Post: 23rd January 2008, 23:06
  4. Quick tyre question...
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2007, 17:22
  5. Quick tyre question ...
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2006, 17:27
