Results 1 to 3 of 3
Thread: Switched power cable (headunit)
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default Switched power cable (headunit)
    Does any know where the switched power cable, that ends in the ISO block for the headunit, comes from?
    Does it go through a relay or anything like that?
    Because im gettin no power through it and I cant find where it goes.
    Carl
    My vec is a 2003 1.8LS if that makes a difference.
    just found what the problem was.
    I had taken out the info display (mines the 2 line display thing) as i was goin to replace it with a small screen.
    the ignition/switched live must run through the display cus as soon as i plugged the display back in, i get power from the switched live cable behind the headunit.
  1. Amp power cable
    By vermiculus-daemon in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 15:55
  2. no power to headunit
    By cutchy in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 19:42
  3. No power on new headunit?
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2010, 09:08
  4. What colour is the switched live to the headunit?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 21:45
  5. power & cable poliser ( PC )
    By ian_c in forum Detailing and Car Care Discussion
    Last Post: 18th March 2006, 14:03
