Thread: can I get away with a 40/30 drop on 19's ?
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default can I get away with a 40/30 drop on 19's ?
    As above I have my 19" snowflakes and I'm wanting to lower it using a Bilstein B12 kit which includes lowering springs that take it down 40mm at the front and 30mm at the rear, the car is a 3.2V6 Elite, I'm currently judging by the huge space between the tyre and arch at present, so going from that it should be fine, I just wanted to be 100%
    http://www.balancemotorsport.co.uk/p...ecnumber=56217
    that's the kit, only I'm getting mine from LMF
    SOMERSET
    I have seen a 45mm front and 40mm rear and it looks fine but 40mm front and 30mm rear may make it look like it's nose diving(possibly).
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    I was going tr try this exact thing, as i'm not too happy with how the front of my car sits at present after being lowered.
    I was speaking to Mark(GSI 3.2) last night, and he advised against it, cant remember the reason now, but am sure it was along the lines of what Pimm says, about it being out of proportion at the front. I suppose the ontl way too see is to actually try it.
    Am i right in thinking that Spoons's VXRD is lower at the front than at the rear??
    SOMERSET
    Quote Originally Posted by BigMan77 View Post
    Yes, i beleive it is a 5mm difference and not 10mm. same for Payney.
    yep, the tail will sit high unless you are lucky..best to go for a level drop if you can..Eibach springs give you a level drop, see LMF's website for details
    Engine : Z20NET
    It's LMF where I'm getting these from and Steve is raving about them saying that they are top of the range from Bilstein,
    I always remember the Eibach coilovers I had on my Astra G when fully wound down made the car lower at the front than at the rear, when I look at the Vectra from a short distance there is a much bigger gap at the front than at the rear with the standard springs and shocks,
    how it looks is not my concern though, how it handles and if it will rub/catch at all is, as I said the Astra was lower at the front and handled superbly, I imagine if Bilstein are making the kits like this there must be a purpose.....
    it'll handle like a train on rails....and the wheels won't catch if you're on VX offset rims.... so enjoy..
    Engine : Z20NET
    Thats what I wanted to hear
    Cheers once again mate, I can't imagine 10mm making too much of a visible difference on a car that size anyway, + as I already said the wheel-arch gap is bigger at the front than at the rear = more space to drop
    Will post before and after shots
    henfield
    thanks for the link. unsure why you won't consider buying through my business. guess it's a vauxhall thing? anyway seeing as you had various questions let me answer them:
    will it work with 19s - wheel diameter is irrelevant - you must keep within 3% oe rolling radius
    why 40/30 - rake is vital - all cars rake down at the front - arch gap is meaningless - look at actual ride height - most cars have rear arch lower than front by many mm but actual rake is much lower. more rake will descrease drag, increase front end grip, reduce understeer. all good on FWD car
    be nice to know why we don't get a look in even though we get the link :-)
  1. Stick with the 19's or drop down to 18's?
    By PeteD in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 20:22
  2. The 19's are on
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 22:48
  3. vxr 19's
    By kpf1grandprix in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 6th February 2009, 22:35
  4. Vx 19's **Help Please**
    By Saimir in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2006, 15:50
  5. NEW 19'S-- Got them (nearly)
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2006, 19:38
