Thread: noise coming from the air circ fan
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default noise coming from the air circ fan
    when its on either 1 or 2 - the fan unit squeeks at me, does any one know how to cure it.
    I think the bearings are either dry or knackered.
    thx if you can help.
    remove the fan motor and spray grease the bearings...motor is located up and behind the glovebox
    Suffolk
    can you go through the pollen filter, coz you can clearly see it, how do i remove it, or do i not?
    it MAY be possible.. follow the 'how-2' in that section to remove the pollen filter and see if you can get to the spindle, but it's prob easier to just remove the glove box ( screws) and then access the unit from under the dash
  1. Knocking noise when coming to a stop
    By preecy in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 21:54
  2. Noise coming from the rear
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:16
  3. Problems - whining noise coming from 5 gear
    By toughmat in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd September 2011, 08:50
  4. grinding noise coming from rear wheels
    By pud wayman in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2011, 07:27
  5. Air re-circ mechanism noise
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2008, 21:24
