Thread: ECU Reset
    Regular Member korlinski's Avatar
    South
    Default ECU Reset
    When I had a Lexus GS300 i could remove a fuse for about 60 seconds to reset the ECU (so the car can relearn new conditions with an air filter added also learn how I drive again)
    Can I remove the fuse. if so which????
    If not how long do need to remove the terminal of the battery to reset the ECU if there is no fuse.
    Regular Member shan's Avatar
    I think it's for 15 minute's mate. I'm not sure if their is a fuse.
    Just disconnect the -ve terminal for 10-15 mins, that'll do the trick.
    May 2006
    scotland
    There is an ECU fuse in the fuse box under the bonnet. I did this with my car a month back to save hassle of windows reset etc but TBH mines has full canbus and only windows reset is required after a battery disconnect so less hassle doin the battery. If you have to pull the fuse, its a bit of a james hunt to get out using the supplied tool. I ended up compressing the tool onto the fuse using pliers to get it out. Sorry am at work just now so cant remember the fuse number. Its in the handbook, if you have one.
    Given that, a disconnection of the -ve terminal definitely sounds much less hassle!! The windows reset and typing in the radio code again are a doddle.
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    Given that, a disconnection of the -ve terminal definitely sounds much less hassle!!, The windows reset and typing in the radio code again are a doddle.
    what is the windows reset? and why do you have to reset them after taking the battery off?
    The auto feature stops working i.e. when you push and hold the button for a second and the windows keep going up/down after you've let the button go. All you need to do is wind the window down, wind it back up but keep your finger held on the button as it goes up. Keep it held for a couple of seconds once it has closed until you hear a faint click, that's it reset. You need to do the same for each electric window including rears if you have them.
    Jun 2007
    5 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    i thank you .....once again
  1. ECU reset
    By wilson002 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 19:15
  2. Sat nav reset.
    By welshboy in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 03:12
  3. EML reset
    By paul_sri150 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 14:15
  4. ECC Reset??
    By colalowe in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2008, 20:42
vectra c reset ecu
vectra ecu reset
reset ecu on vectra c
resetting ecu on vectra pulling fuse
reset ecu opel vectra c
vectra cdti ecu www.vectra-c.com
vectra c ecc zur├╝cksetzen
ecu fuse vectra c 2008
vectra c ecu fuse
vectra back up battery ecu
will taking fuses out reset ecu vectra
vectra c cdti ecu fuse
