Thread: Squeaky Brakes??
    Regular Member Ralph wiggum's Avatar
    Oct 2006
    Bexleyheath, Kent
    Angry Squeaky Brakes??
    I replaced the Pads front and Rear today with EBC " Green Stuff " Pads, and now there is a horrible squeel and Grind under braking..... Is this just the Pads "Bedding in" or something else???
    N.b It does say on the EBC Box that they are coated with something to "Assist" with bedding in, and NO Hard braking for the 1st 100miles
    Please help cos it's driving me crazy...will it go after time??
    [Ex]Admin Duncan's Avatar
    Did you Copaslip the back of the pads when you fitted them? If not, then that's be the first thing to do.
    Oct 2006
    Bexleyheath, Kent
    Yeah, a bit but not much
    Regular Member hagga's Avatar
    kingswinford
    is it from both sides? I fitted red stuff and had no probs..these have the bedding in surface too.
    Oct 2006
    Bexleyheath, Kent
    Sounds like both fronts
    kingswinford
    Quote Originally Posted by Ralph wiggum View Post
    hmm..I'd expect a slight grinding for a while..due to the rough bedding in surface..but not the squeal...I did give mine a decent smear of copperslip.
    A good dollop will ensure they don't squeal. Maybe just whip them out quickly and slap on a bit more to see if it helps.
    Oct 2006
    Bexleyheath, Kent
    Just got this off the EBC Website: www.ebcbrakesdirect.com
    NOISE - Light whistling/squeaking (at walking pace)
    This noise usually happens as the vehicle is coming to rest and is again typical of a pad that is just bedding in or has been under used. Again the remedy is to allow a few hundred miles for the pads to properly seat and have 100% contact surface against the disc. If the problem occurs intermittently, one good cure is to use the brake severely every day now and again on a safe secluded low traffic piece of road to “de-glaze” the surface of the brake pad. Obviously extreme caution must be used when performing this action
    Hope this is all it is
  1. squeaky brakes
    Last Post: 22nd June 2010, 13:19
  2. What causes Squeaky Brakes (Vec-B)
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 09:47
  3. Squeaky Brakes
    By BENNYBED in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2008, 14:44
  4. Squeaky Brakes
    By smithi in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2007, 15:03
  5. Squeaky Brakes
    By tj 666 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2007, 23:18
