Results 1 to 10 of 25
Thread: Can anybody help me please ??
    SOMERSET
    Default Can anybody help me please ??
    I have had this slight wobble on my car ever since i have changed my alloys.
    My original 17's are perfect but the 19's wobble. I have had them balanced three times by different garage's who say they are fine but this never makes any difference. This is driving me . I have had new trackrod ends and other bits relating to suspension replaced but still the wobble is there.
    If a member that has 19's on would be happy for me to meet up with them so i could try there wheels on my car so i could test to see if my 19's are a issue OR my car does not like the bigger wheels on, i would be happy to travel within reason and i will get you a beer or two.
    Before the posts start, i have swapped wheels around and tyres and the tyre pressures are correct but i wonder if it is to do with me having to use spiggot rings on at the moment and my car does not like this.
    are you using the rings to centralise the wheels on the hub? Is the pcd 110 or are you using wobbly bolts?
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    check your elbow on each wheel might be a bearing needs replacing or hevens forbid the stearing rack on way out.
    regards nig
    SOMERSET
    Quote Originally Posted by Astrase20 View Post
    The rings are to be used to centralise the wheel and they are the correct ones. I do not need or use wobbly bolts as the fitment are correct.
    SOMERSET
    Quote Originally Posted by nph1 View Post
    regards nig
    My car had a MOT last week done by the stealers and it pasted fine so hopefully no problems in that department.
    I wonder if the make of alloys are ******s to balance hence causing me this problem.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    could it be that one or more of the wheel's is slightly buckled, or the tyres are out of shape ??????
    just spoke to a mate of mine in the trade and he said these things
    Midlands Mod Shop - NFFC.
    Quote Originally Posted by PIMM View Post
    Some are harder to balance, it could also be a bad batch of tyres
    SOMERSET
    If i can try someones 19" snowflakes or vxr rims that would be perfect and then should give me something to go on.
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Have you tried swapping fronts with backs PIMM (I know you said swap but not sure if that was back/front) – does it still happen?
    SOMERSET
    Quote Originally Posted by Swatty View Post
    Yes i have swatty, iam so fedup with driving with this wobble i feel sometimes like getting rid of the car. As said in my ealier post the original 17" rims are fine but i do not like the look of the wheels.
