Results 1 to 10 of 18
Thread: Estate Rear Bumper Removal And Parking Sensors
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Default Estate Rear Bumper Removal And Parking Sensors
    Going to buy and fit some sensors to rear bumper but when I looked underneath there's a big aluminium bar in the way. Has anyone fitted sensors to their estate and, if so, did you have to take the bumper off ? Facelift , by the way, incase it makes a difference. How easy is bumper removal on these ?
    Ta
    Belfast
    interested in hearing how you get on mate. Should be picking my v6 estate up end of next week! Good luck and post some install pics if you can.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Mine are fitted to the black strip at the bottom, as are the factory installed ones. Sorry don't have a pic as I am away in the Emerald Isle supping the glorious water. Can post one for you Friday
    May 2007
    West Yorkshire
    As above, no need to colour code then, and if you make a hash of it you can replace the strip instead of the bumper.....
    Regular Member shan's Avatar
    Am i correct in thinking you have no problem with the sensor's being quite low. I'm thinking of placeing sensor's on my signum. Middle 2 in the strip and outer 2 on the bumper.
    Quote Originally Posted by shan View Post
    Mine works really well. I've got a Zaffy with factory fit ones and my aftermarket ones seem to work better. Fitted in the same place as the factory ones on the Vec.
    Willc01. I just looked at the picture of your rear . And i dont see the sensor's. Is the picture before you fitted them
    Shan, yes I know, all the pictures need updating and its on my list but if I take new pics it means the car needs a real clean. I've added the Irmy grille, new number plates and when I get the new skirts on, I'll update all the pics.
    Regular Member Steve CDTi's Avatar
    Wirral
    BE VERY CAREFUL drilling into the painted bumper to fit aftermarket sensors. The metal bar behind is slightly concave and the sensors will fit into it, however only at the correct height. There is no way externally of telling however and I really would recommend dismantling as much as you can to avoid an expensive mistake.
    I did make this mistake, and needed to re-drill the hole slightly higher in the bumper to fit the sensor. It needed some filler and a paint touch up to cover it however.
    Fortunately.... the rear bumper (and sensors) were written off in an accident a few weeks later, and were subsequently replaced by the factory fit ones in the lower unpainted part of the bumper. These work very well and have had no problems with them being too close to the road (and with the lower SRI suspension). This was unlike the first sensors which despite being mounted higher did get reflections off the road surface quite often.
    Hope this helps - and please be careful drilling from the outside...!!
    Steve
    Belfast
    do they work on the lower (unpainted) valence, with a tow bar fitted?
  1. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  2. estate rear parking sensors
    By Ryanlfc in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 20:34
  3. Estate - want to install parking sensors in rear BUMPER
    By FinnRolo in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2009, 10:35
