Thread: Not sure if oil leak or what?
    Jun 2007
    west yorkshire
    Default Not sure if oil leak or what?
    Hi
    I have a vectar 2003 model 2.2 dti.
    I noticed a few drops on my drive checked underneath the car but the cover is in on. So i put card board under where it seems to be and no drops this morning.
    Seems like its proper dirty down there not sure if its a leak? its proper dirty, and dry!
    could it be that previously that if something was changed it was made dirty and the car when it heats up lets some **** down.
    If there was a consistent leak would there defintely still be some marks everyday as it would seap through the cover or would the cover hold it?
    cheers
    TJ
    Oct 2006
    Yorkshire
    if it's only there after using the a/c then it's condensation run off from the air conditioning, I wouldn't worry about it.
    Jun 2007
    west yorkshire
    Hi
    No the smells happens sometimes espcially when its heated but it comes and goes.
    i looked under the bonnet noticed that there dry oil near the gasket not aroundJ the seal as it was clean there. Looked at the CV boot near the wheel and it had dried out oil. Must be from before??
    i know the previous owneer had a full service in februaury which had somebelt changed, oil etc... and also the turbo went on it last year and he had that changed?
    if there was a consistent leak would it not come through the plate at the bottom? it seems all dried out so could the smell be burning oil?
    cheers
    Jun 2007
    west yorkshire
    Just to add to the above it onyl smells when stationary but goes when driving normal
    Nicking Ya Dinner.
    Take the cover off, you may have a leaking injector pipe, by the time it hits the floor it looks black and gunky.
    Jun 2007
    west yorkshire
    will do is that expensive to sort out?
    Jun 2007
    west yorkshire
    Hi
    Took car to the garage the leak is coming from the pipe in turbo might be loose the guy said. getting fixed on thursday. saw the leak which is very slight!
    but has made the engine dirty! you reckon steaming will be ok for the car dont wanna end up messing anything else up
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Yes, steaming should be ok, but avoid the electrical components and connectors and most importantly the ecu's
    Done mine twice and no ill effects..
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
