Thread: gearbox oil change
    Regular Member jamesr's Avatar
    Lancashire
    Default gearbox oil change
    Can anyone post a quick how to on changing gearbox oil on a 1.8?
    it's not really neccessary to change the gearbox oil on manuals. it's not a service item at all...
    if you do want to change it, there is no drain plug, and if you need to refill, then use the breather hole with the breather valve removed.
    Jul 2006
    Mexico
    By the way.... where the hell is the deep stick to check the level on a 3.2 V6 box? Is there one at all? How do you check the gear oil on this thing
    down the front of the gearbox Rob..look down there for a 1" diameter green button, secured with a 13mm headed bolt...thats the stubby gearbox level dipstick on the automatic..
    Jul 2006
    Mexico
    Once again GSI...thanks for the enlightment
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
https:www.vectra-c.comforumshowthread.php26835-gearbox-oil-change
