Thread: No Instruments or Radio?
    Regular Member pauls898's Avatar
    Malvern
    Default No Instruments or Radio?
    I experienced a really strange fault today?
    Got in the car as usual to come home, normally when you get in the car, the central display lights up to greet you with displaying the outside air temperature and date/time? However this was off
    Started the car, Car started normally, then I noticed no Tachometer or fuel readings, no radio, no central display indication no nothing??? But engine was running fine?
    I switched on the lights to see if that would make the display come on and everything came back on
    Got home and I checked fuses, and relays for sitting etc. Non were loose.
    I read somewhere this could be due to an ABS plug or CIM module plug?
    If this is the case where is the sim module plug to be found so I can check that for tightness?
    Not managed to make this happen again yet
    Paul
    [Ex]Admin Duncan's Avatar
    CIM module is inside the steering column.
    Malvern
    Could that be a possible cause to my symptoms as explained?
    Or another question is? Is the air temperature sensor have to be registered to the CAM bus? because the only recent change was due to front end accident with a badger, I had to have all the front of the car replaced i.e. new front bumper, radiators and grill including this air sensor, as it was displaying -40 deg C when it was broken lol
    Could be related. I remember Mark (GSi3.2) telling me the other day that he went to start his car the other day and hadn't reconnected his fogs and ATS after taking his bumper off, and the dash lit up with warnings! - opposite to yours though! Whether it was the fogs, ATS or both that caused the problem isn't clear.
    Given what you've just said about the front-end damage, I'd check your fogs and ATS first. They would have had no need to fiddle around with the CIM.
    Malvern
    Whats the ATS?
    Thanks Ducan
    Air Temperature Sensor.
    Malvern
    Off course silly me
    Yes that s now displaying the correct reading, but does it still require a Tech 2 to register that unit correctly to the ECU? as they have replaced it? or I would gues its just a passive resistance device, but I could be wrong bearing in mind the car was repaired at a repair centre and not a VX dealer, so I doubt it very much they would have tech 2 it?
    Regular Member Petrolhead's Avatar
    Mar 2007
    Sheffield
    I had a similar problem a few months ago, started car and noticed central display not lit, didn't notice rev counter etc...but turned engine off and then back on, no fault. Put this down to general computer fault that required it rebooting by turning ignition off. Not had a problem since.
    Quote Originally Posted by pauls898 View Post
    In which case I'd just put it down to a glitch as above and not worry about it unless it happens again.
    Jul 2006
    Another badger incident in Malvern? That's got to be more than coincidence!!! Unless you're MLC in disguise....
  1. Instruments all dead.?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2010, 20:52
  2. Loss of instruments
    By tangoman in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 07:54
  3. Replacement instruments .
    By Suffolk Boy in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2009, 20:54
  4. What instruments....
    By lofty in forum The 'Off Topic' room
    Last Post: 5th November 2008, 04:09
  5. Instruments problems!!
    By andy1103 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th June 2008, 21:09
