Results 1 to 10 of 21
Thread: button around stereo on pre facelift
    Regular Member korlinski's Avatar
    South
    Default button around stereo on pre facelift
    Hello everyone,
    I have the Veccy Elite, and around the stereo there are 3 blank plates for switches.
    What can go there? Behind 2 of them is an plug. Can i just plug in the switch to get the extra function.
    The blank locations are bottom right, second to bottom right and bottom left.
    I found a plug behind second to bottom right (traction control switch???)
    cheers
    Quote Originally Posted by korlinski View Post
    BR = Sports Switch, Above that is TC switch, BL = Park Pilot (parking sensors)
    If you have a plug behind the TC one then it may work with a switch plugged in - it's kinda hit and miss whether it does or not.
    South
    Sports switch??? what does that do??? I like the sound of that
    Also I assum the TC switch turn TC off and on.
    How much can I get these for and where from (appart from dealer)
    No use unless you had the options factory fitted - links into the suspension, steering and throttle to sharpen responsiveness and suspension damping.
    Yep, that's what it will do if the switch works in your car. There's no pattern to year/spec as to whether a retro-fitted TC switch will work or not.
    Dealers - best place. About £10-12. Look in the part numbers section for the part number.
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 193000
    daft question, but how do you take the blanking covers off?
    Several options....
    • Gently prise off with a screwdriver. Advisable to wrap masking, or similar , tape around tip so as to not mark trim.
    • Remove stereo and they can be pulled with fingers from the edge
    • Take a big blob of blu tack, or stickier black tack, and push onto cover and pull and it will come off.
    Jun 2007
    Vehicle : Vectra c
    Year : 06
    Mileage : 193000
    cheer's boss
    Regular Member Petrolhead's Avatar
    Mar 2007
    Sheffield
    I have the 3.2 GSI and have not got heated seats, yet behind the blanking plate s there is plugs does this mean if I buy the switches I will have heated seats !!!
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Quote Originally Posted by Petrolhead View Post
    No, it seems that most vecs have the relevant plugs but they dont go anywhere.
    They can be retro fitted, as can the rear heated seats I believe. Just need the right parts. Its been covered on here somewhere.
  1. On/Off Button Broken on Stereo 53 plate vectra
    By akeem in forum Bodywork & Interior
    Last Post: 7th November 2012, 00:53
  2. chrome button dash vents from facelift into pre?
    By matthew8814 in forum Styling
    Last Post: 28th February 2012, 14:30
  3. 3 Button Flip Key on Facelift
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 19:14
  4. pre facelift stereo help
    By mattolly86 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2009, 00:00
