Results 1 to 10 of 17
Thread: cruise cont prob
    Regular Member jay-z's Avatar
    east mids
    Default cruise cont prob
    ive got a 03/53 sri turbo vec and the cruise doesnt work, its got the controls on the stalk but the check light doesnt come on when i put the ignition on, i looked for the fuse but cant find it.
    any ideas
    cheers
    Full Member Big Sig's Avatar
    I don't think is does come on with the ignition.
    You have to push the brake pedal while driving first. Then it shoulod come on with the buttons on the stalk. If it doesn't try it while lifting the clutch pedal with your toe. Sometimes the spring on the pedal breaks and may need replacing.
    oh and
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Astrase20 View Post
    You have to push the brake pedal while driving first. Then it should come on with the buttons on the stalk.
    You don't need to have pressed the brake pedal once for CC to work. Well at least I just have to when I just tested it.
    Quote Originally Posted by Ste View Post
    I have to on mine. If I drive off and try the CC it won't engage until I have used the brakes at least once.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Spring broke
    It seems the clutch pedal spring has broke. there is a modified part from vx which takes about 1 min to fit. Had the same problem with my 52 plate sxi
    Jul 2006
    I've never seen a check light on mine when i turn the ignition on. But as above, with mine i have to brake at least once while driving before the CC will engage.
    east mids
    cheers guys, i had a look underneath behind the clutch pedal but the spring seems fine. there doesnt seem to be any play in the spring and i cant pull the cluth pedal forward, according to the drivers manual a symbol like the top one on the cruise stalk should light up when ignition is turned on.
    Regular Member graham a's Avatar
    hull
    no light on mine when i turn the ignition on.my cc only works when the brake pedal has been pressed,then i get the green indication on the dash
    east mids
    when does the green light come on graham a, is it when criuse is on
    Yep, only when the cruise is active.
    Sean
  1. Air con prob
    By graycbox in forum Introduce yourself.
    Last Post: 19th July 2010, 22:15
  2. ABS ecu prob
    By CBag7 in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2009, 13:12
  3. i think i have a prob
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 23:09
  4. cruise, abs, tc Prob/fault
    By SteveH in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2008, 23:03
  5. 2.2 sri prob
    By junior72 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2008, 22:37
