Thread: Rear seat belt stuck.
    Co.Antrim
    Default Rear seat belt stuck.
    I'll tell you'se what the problem is, I had to put down the rear folding seats to fit something in. When I came to put it back up the middle seat belt would not pull out rendering it useless. I was wondering has anyone else come across this problem and what did they do about it. I have three boys so need three seat belts as you can imagine.
    Regular Member vectravirg's Avatar
    Bolton
    Yep same thing happened to me a few months back,it is a common problem as when I did a search on here, I could see it had happened to a few others.
    Mine was still under warranty so the dealers sorted it out, is yours older than 3 years?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, I suspect the seat back it not securely back in place.
    There is an interlock to prevent seat belt extending if the back is not secured. Try releasing the back and then push it back with a bit more force.
    Look at the release handles, they should both be flush with the surround.
    Co.Antrim
    yes the car is over 3 yrs old.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    no - is it a word association game ?
    Nicking Ya Dinner.
    Try this before you spend mate, I assume it's locked itself tight? if so pull hard on the lower part of the webbing, and at the same time try to feed the webbing in to the slot it comes down from, failing that, you will need to take the trim off and unbolt the belt at one end to release the inertia. hth
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    I'm with Ste on this, lower the seat and slam it up again (harder, and then harder still) then try the belt. There should be no red visible on the release catches when the seat is correctly locked in position.
    Co.Antrim
    Did all that was advised but to no avail, bought car to dealer and as theres two weeks left of the Network Q warranty left the have ordered a new reel for me. A dealer doing right by me for once. Thanks for the advice guys.
    Regular Member Karl's Avatar
    Sunderland
    nice to see you are getting it sorted, do us all a favour and ask the dealer if there is a quick fix for this should it happen again, I regularly have a full car load and wouldn't want to be left with a loose passenger behind me.
    May 2006
    scotland
    Worse still if the loose person in the back was 'a person of the cloth' a cannon maybe.
  1. rear middle seat belt stuck i can help
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 12:26
  2. Drivers seat belt stuck!!! Help
    By degsy1234 in forum Bodywork & Interior
    Last Post: 23rd December 2010, 15:23
  3. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  4. Seat Belt Bolt T45 Stuck
    By Warrenmole in forum Bodywork & Interior
    Last Post: 11th April 2009, 19:57
  5. Rear Centre Seat Belt Stuck
    By Angelchops in forum Bodywork & Interior
    Last Post: 2nd January 2007, 13:10
