Thread: Front seat belt removal
    uk
    Default Front seat belt removal
    hi all
    First let me thank the group for it's help! I read past articals and I sorted out my cdr 2005 radio/cd problems.
    OK! here is my current problem - What tool do I need to remove the n/s front seat belt housing? I have got a new one but the nut that holds it looks like it needs a special romover!!!!! again.
    Thanks in advance
    Kel
    As a side issue is there anywhere in the blackcountry area that can put my car on test (computer) at a reasonable cost because I know that if I go to a dealer i'll get no change out of £200 (experiance). Because the air bag is lit on my instrument panel. While i'm on..... I have intermitant problem with my cruse control, sometimes it will not work!
    My car is -vectra 1.8 club, saloon, 52 plate. It's nicer with a boot!
    the nut that holds it to the door pillar is reached through a hole in the B pillar thats blanked with a black cap.. what you need to use is a 13mm tube spanner, that will get over the plastic nut guide spigot..then the one on the seat is just a standard torx, as is the top mount..
    if the airbag light is on, try wiggling the wires under the seats as they are usual favorites to trigger the system into faulting.....
    cruise control problems are usually caused by the clutch pedal spring failing to return the pedal up high enough, and then failing to close the clutch switch..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep broken clutch pedal spring would cause your CC not to work, there is a modified part from VX. Do it asap as it will also wear your clutch. Had same problem on my 52 SXi
    uk
    kel
  1. Rear Seat Belt Removal - Vectra C
    By tutfut01 in forum Bodywork & Interior
    Last Post: 16th September 2010, 10:28
  2. Front Seat Removal
    By Tam80 in forum Bodywork & Interior
    Last Post: 14th September 2010, 22:48
  3. signum seat belt removal
    By lepip in forum Bodywork & Interior
    Last Post: 28th July 2008, 11:37
  4. Front Seat Removal.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2008, 12:18
  5. Rear seat belt removal
    By monkeybusiness in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2006, 15:16
corsa c seat belt removal
how to remove a vecrtra c seat belt
tools needed to change a rear seat belt in a vauxhall vectra c
vectra c seat belt tool
tools needed to remove vectra c seats
remove vauxhall seat belt
remove seat belt from 2006 vectra
fix vauxhall vectra seat belt
vectra c front seat belt removal
vectra Seat Belt Removal
changing seat belt vectra o7
