Results 1 to 10 of 14
Thread: Fault code P1590
    Trondheim, Norway.
    Default Fault code P1590
    Hi.
    I have a bit of a problem, I'm supposed to leave for Germany this week.
    BUT as always when I have something I really want to do my car decides to give me hell... (But somehow I always choose Opel way before other brands)
    This time it's the fault code P1590, my engine code is Y22DTR.
    In norwegian the code translates to:
    Fordamping Vakuumsolenoidkrets.
    I have no idea how to translate that to english.
    So i hope anybody here have had the same fault code and remembers what i was. Any tips at all?
    Regular Member sig63's Avatar
    Aug 2006
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by Eivind View Post
    Hi.
    In German:
    P1590 = Unterdruck Magnetventil
    Causes:
    Spannung zu groß
    Spannung zu klein
    Stromkreis offen
    Endstufe Temperatur zu groß
    Trondheim, Norway.
    Can you translate the causes to english?
    It would help a lot.
    Edit: Where did you find that? Autodata/TIS or something?
    Regular Member dave45040's Avatar
    Aug 2006
    llandudno
    Quote Originally Posted by sig63 View Post
    In German:
    Causes:
    Spannung zu groß
    Spannung zu klein
    Stromkreis offen
    P1590 = low pressure magnet valve Causes: Tension to largely tension to small circuit openly final stage
    temperature too largely
    Regular Member Geoshaw's Avatar
    Mar 2006
    Armadale (West Lothian)
    Using the gendan website it comes up with
    P1590 : vauxhall = Ignition switch, supply voltage - out of limits
    Regular Member benny's Avatar
    Feb 2006
    dudley
    check the altonator isnt over charging ......
    Trondheim, Norway.
    I guess the magnetvalve is the same as the EGR valve?
    This thing costs 5000 nok,- (about 500 pund)
    I'll check the altonator tomorrov, the faultcode comes and goes.
    Maybe it's just my head playing with me, but it seems to come more often when i use a lot of electricety. As the AC, CD/radio etc...
    But then again, it should not have an affect on the EGR-valve?
    Technical directors office
    Eivind, as benny said above, get the alternator checked out.. if if comes on a lot more when you use a lot of electricity then it should be even more of an indication that it's at fault to you..
    Melbourne, Australia
    Hmmm, I came up with:
    P1590 = Vacuum Solenoid Valve Powerstage High Temperature
    • The ascertained Control Unit temperature is out of range
    • Above condition must be fulfilled for at least 0.6s
    I don't really know how diesel ECMs work so I can't offer any advice.
    Trondheim, Norway.
    Default Problem fixed!
    Quote Originally Posted by Gsi3.2 View Post
    Checked this last night, the alternator was working fine.
    Quote Originally Posted by stevedee3 View Post
    I guess ECM is the same thing as we call EGR valve. I went back to my garage and checked the faultcodes again, this time it came to codes.
    The same code as last time, and a new one (don't remember the exact code). But everything pointed to the EGR valve.
    Changed the valve and now I'm 500 pund + mva poorer. But the car is working fine.
    Thanks for all the help
  1. y22dtr P1590
    By RyanNI in forum Engine & Drivetrain
    Last Post: 19th November 2012, 21:05
  2. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  3. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  4. Replies: 11
    Last Post: 26th June 2011, 19:29
  5. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
p1590-04
https:www.vectra-c.comforumshowthread.php26763-Fault-code-P1590
p1590 opel vectra c
Zafira 54 fault p1590
vectra c 22tdi p1590
vectra code 1590
P1590 kod chyby
vauxhall vectra fault codes p01590
p1590 vauxhall y22dtr
opel code p1590
P1590 Unterdruck Magnetventil Spannung zu groß
p1590 vectra c
