Results 1 to 10 of 14
Thread: Fault code P1590
    Trondheim, Norway.
    Default Fault code P1590
    Hi.
    I have a bit of a problem, I'm supposed to leave for Germany this week.
    BUT as always when I have something I really want to do my car decides to give me hell... (But somehow I always choose Opel way before other brands)
    This time it's the fault code P1590, my engine code is Y22DTR.
    In norwegian the code translates to:
    Fordamping Vakuumsolenoidkrets.
    I have no idea how to translate that to english.
    So i hope anybody here have had the same fault code and remembers what i was. Any tips at all?
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by Eivind View Post
    Hi.
    In German:
    P1590 = Unterdruck Magnetventil
    Causes:
    Spannung zu gro▀
    Spannung zu klein
    Stromkreis offen
    Endstufe Temperatur zu gro▀
    Trondheim, Norway.
    Can you translate the causes to english?
    It would help a lot.
    Edit: Where did you find that? Autodata/TIS or something?
    Regular Member dave45040's Avatar
    llandudno
    Quote Originally Posted by sig63 View Post
    In German:
    Causes:
    Spannung zu gro▀
    Spannung zu klein
    Stromkreis offen
    P1590 = low pressure magnet valve Causes: Tension to largely tension to small circuit openly final stage
    temperature too largely
    Regular Member Geoshaw's Avatar
    Armadale (West Lothian)
    Using the gendan website it comes up with
    P1590 : vauxhall = Ignition switch, supply voltage - out of limits
    Regular Member benny's Avatar
    Feb 2006
    dudley
    check the altonator isnt over charging ......
    Trondheim, Norway.
    I guess the magnetvalve is the same as the EGR valve?
    This thing costs 5000 nok,- (about 500 pund)
    I'll check the altonator tomorrov, the faultcode comes and goes.
    Maybe it's just my head playing with me, but it seems to come more often when i use a lot of electricety. As the AC, CD/radio etc...
    But then again, it should not have an affect on the EGR-valve?
    Eivind, as benny said above, get the alternator checked out.. if if comes on a lot more when you use a lot of electricity then it should be even more of an indication that it's at fault to you..
    Melbourne, Australia
    Hmmm, I came up with:
    P1590 = Vacuum Solenoid Valve Powerstage High Temperature
    • The ascertained Control Unit temperature is out of range
    • Above condition must be fulfilled for at least 0.6s
    I don't really know how diesel ECMs work so I can't offer any advice.
    Trondheim, Norway.
    Default Problem fixed!
    Checked this last night, the alternator was working fine.
    Quote Originally Posted by stevedee3 View Post
    I guess ECM is the same thing as we call EGR valve. I went back to my garage and checked the faultcodes again, this time it came to codes.
    The same code as last time, and a new one (don't remember the exact code). But everything pointed to the EGR valve.
    Changed the valve and now I'm 500 pund + mva poorer. But the car is working fine.
    Thanks for all the help
  1. y22dtr P1590
    By RyanNI in forum Engine & Drivetrain
    Last Post: 19th November 2012, 21:05
  2. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  3. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  4. Replies: 11
    Last Post: 26th June 2011, 19:29
  5. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
p1590-04
vauxhall vectra fault codes p01590
p1590 opel vectra c
P1590 Unterdruck Magnetventil Spannung zu gro├č
opel code p1590
p1590 vauxhall y22dtr
p1590 vectra c
P1590 kod chyby
vectra code 1590
