Thread: Went to the garage today.............
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    Default Went to the garage today.............
    .........to have the brakes sorted (I know its a simple job but really couldnt find the time!).
    Went back to collect this evening and the guy gave the keys back and said that the pads were still at less than half worn? I trust the mechanic, hes from the old school and very reliable. The warning light came on just over a month ago in the normal way, and reset every time the ignition was switched off.
    More recently the little tell tale on the rev counter has also been flashing to tell me that a bulb has gone when quite clearly it hasn't.
    Anyone got any bright suggestions?
    Garage man thinks it might be a problem with either tell tale or something else.Its going back in on wednesday to have the fault codes on the ecu read.
    Mine told me I had a bulb out and it was fine. A week later it was still telling me and it had blown.....how did it know
    Check the warning cable from the pads, it could be that.
    bulb fault light can be caused by poor contact between the bulb and the bulb holder, so clean the contacts..and that means all of them ....
    and a broken wire in the sensor loom will give you the brake pad warning light..so it could just be the cheap wire
    Regular Member benny's Avatar
    Feb 2006
    dudley
    bulbs on vec c can be out and look ok if you stand well back from the cars you can then have a better idea of wich bulb is out .....also there is a known problem with the brake pad warning lights giveing incorrect readings most dealers have been programing the warning system out as they do give a little glitch from time to time on different cars ......ask the dealer about it ..or if some one on here is able to read tis could find the feild remedy for it ..hope this helps benny ....
    Cheers boys, anyone got anymore details about what Benny is talking about? Would it help to change the sensor itself?
    Feb 2006
    dudley
    it may help if a new sensor is fitted ..just to be 100% but if still on after that will need a reprog
  1. Been in the garage today.
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2012, 21:37
  2. car in in the garage today
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2009, 14:04
  3. had car in garage today over fuel consumption
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2009, 17:56
  4. spotted this today in milton keynes today.
    By kev bux in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 09:00
