Results 1 to 10 of 17
Thread: Tyre Pressure
    Larkhall
    Default Tyre Pressure
    I checked the tyre pressure on the car about 4 weeks ago and 3 of them were spot on apart from the driver side rear, which was down to 16.5 psi. The manual says for my car they should all be 32 psi so i pumped it up to 32 and that was fine. Checked them again tonight and found the same problem with the same tyre.
    Is this just down to the car being used everyday or is there a problem with it? It only seems to be that tyre as the rest are always unchanged........???
    there's a small leak somewhere, so get it to a tyre centre and get them to look at it, it could be a leaky valve or a leak on the rim...they will find it for you..
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Sounds like a puncture or leaking valve or something. Go down to your local tyre place and get them to check it out.
    I had the same thing the other week with one of mine, was losing 3-4psi a day. Got it off and it had 2 nails in it. One was repairable the other wasnt as it was too close to the edge, so the tyre was scrap.
    Wilts
    Fastest finger first eh Mark
    ooh yes, and mine have had a 3 day rest..
    Larkhall
    That's all i need!!
    Got a screw stuck in the front passenger side wheel a few weeks back, went to kwik-fit who quoted me £155 for a new tyre, told them to shove it. Managed to get it plugged for £10........
    Wilts
    What tyre size you got? What model you got?
    Larkhall
    They are all Bridgestone 215/55/R16 and it's a 2.2 Direct Life.
    Just went out and had a look, can't see any obvious signs and I do around 1000 miles a month and it hasn't went completely flat since i last checked...
    Regular Member scottyd's Avatar
    paisley
    watch what they tell you most will say they can fix it when they just want a tyre sale most punctures can be plugged is just that they want a tyre from you rather than apuncture repair just be greatfull they aint goodyears nct's
    Larkhall
    The very first thing they asked me was if the car was a company car or mine, as soon as i said mine they went "Na, cant fix it, new tyre £155"
    Showed it to 2 guys i know who fix them, said they were talking sh!te and that could be plugged. Got it plugged and hasn't even lost the slightest bit of pressure in about 6 weeks!
    This ones a bit of a puzzle. I'd say it's been at least 2 months since i last checked them.
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
