Thread: Questions !!!
    May 2007
    romford
    Question Questions !!!
    hi guys, couple of quick questions for you, gonna be doing oil change and disc and pads. veccy 1.9cdti (120)
    1. is the oil filter easier to get to from the top of the engine or the bottom
    2. does the whole engine cover at the bottom have to come off to get to the oil sump nut.
    3. what is the best oil to use (can get it at trade)
    4. after changing front disc and pads do i need to bleed the brakes
    all comments gratefully received.
    by the way lewis hamilton, did not look right today, maybe too much pressure/expectation on him ?
    Quote Originally Posted by zubs187 View Post
    He forgot to put his makeup on, and was touching it up after being overtaken by a flying Fin
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    no1 i found it better from the bottom rember to cover th zust with a bit of rag
    no2 i removed the whole bottom as it was just as easy
    no3 just use the vx stuff mate (i used castrol edge on my last change)
    no4 no sure
    just take it carful with the sump plug as you not wanting to end up like this if you do give me a shout m8
    http://forum.vectra-c.com/showthread...highlight=plug
    Full Member Big Sig's Avatar
    For No.4 only if you let some fluid out of the caliper.
    May 2007
    romford
    thanks guys, much appreciated .
    Nicking Ya Dinner.
    Remember to get the wind back tool or home made effort for the rear pads, do not just push the pistons back in.
    [Ex]Admin Duncan's Avatar
    No.4 - No need to bleed at all. Pads and discs just swap out.
    Following on from what VV said, a wind-back tool is needed for the rears - although it sounds like you are doing just the fronts? I don't believe there is an actual wind-back tool available for the fronts (stands to be corrected). They don't always need pushed back but when they have I've used a couple of large G clamps which you position carefully and slowly wind each in until you have the clearance for the pads.
  1. Few questions
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2012, 22:59
  2. HID questions
    By Angel1368 in forum Styling
    Last Post: 9th May 2012, 11:08
  3. A few questions!
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2009, 21:38
  4. A few questions.......
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2007, 17:18
  5. Just a few questions ;)
    By BlueRob in forum Petrol Engine related
    Last Post: 24th July 2007, 04:30
