Results 1 to 10 of 20
Thread: How do the std headunits come out?
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default How do the std headunits come out?
    This sounds a daft question i know, and i think im doing everything i should be doing, but i just cant get it to budge...i have removed the grub screws and i have a pair of the 'keys', (Autoleads keys, not vauxhall..suppose that could be the problem?)
    I insert the keys, apply slight outward pressure to the keys inline with every other Vauxhall stereo and stereo's of this type i've removed, and all that happens is the keys just keep coming out...ive even tried jiggling the kegs about when trying to pull on them and all ive managed to do is loosen the actual front of the stereo on the top right corner
    Is there some other fixings some where that i need to remove first?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by John35 View Post
    And maybe not!
    They do tend to stick. Give the pins a good whack to make sure they are engaged properly. I only used an old metal coat hanger and it worked for me.
    Try pulling out the switches around the HU with blue tac then you can spread some pressure around the HU face and give a bit more leverage.
    You could also taking the glove box out and pushing the HU from the back.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Would help if i was messing with headlamps i suppose
    And maybe not!
    I shoved the pins right in and fealt for them clicking in and it still didnt help...i wonder if proper Vauxhall pins would be better?...and I did try taking the switch blanks out on the right hand side, but couldnt get any more out as i was starting to damage the trim, and it isnt my car...its an Elite so it has heated seat swicthes too and i couldnt budge them, and the hazard switch fealt like it was going to break...i dont really want to have to take the glovebox out either...this isnt an easy job is it? lol
    Cheers for the advice though
    Jun 2007
    in a white box
    sorry at the time.
    now read it properly..... use a coat hanger
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    i used the audioleads key to remove mine, took about 10 secs. Make sure the keys are in all the way, if i remember right i had to push the keys in so that vitually the whole of the straight part of the keys were in the holes the levered outwards slighty while pulling.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Also try pulling from one side at a time, bit by bit.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Right ta...i shall have another bash later on...****** things lol
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    as above m8, had to push keys all the way in and give it a good wobble to get it out, the cage is fixed in at the back though and will need to be removed before the new facia/surround is fitted
    Midlands Mod Shop - NFFC.
    Jul 2006
    Here's my 2p....
    1. The Vx HU is a VERY tight fit, as well as using the keys, you'll have to try to wiggle the HU itself, a fraction of an inch at a time.
    2. Removing the glove box is a doddle...if you've got some Torx bits for the screws. Open the glovebox, there's 3 screws along the top edge, and 1 in each front bottom corner. Remove these, and the whole thing just lifts out. 5 mins, max.
    HTH
  1. Factory Headunits
    By bigstorer in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 11:06
  2. Headunits
    By Q22ube in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2008, 00:55
  3. bluetooth headunits
    By Kam B in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2007, 18:14
  4. headunits
    By cr0m81e in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2006, 16:45
  5. Headunits
    By ZC_74 in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2006, 06:53
