Results 1 to 3 of 3
Thread: wheel protector tyre
    kirriemuir
    Default wheel protector tyre
    hi would it be ok to put a tyre which has the thicker sidewall on the front with a tyre that dos,nt ?the size is the same tread wear about the same.both eagles.the reason i ask is i had a side wall punture on one original tyre and had to replace it and it seems to sit higher on the sidewall.looks a bit stiffer
    Thicker sidewall tyres are indicated by the XL or Reinforced status on them
    Rim protectors are vehicle specific and are identical
    Example :
    The Merc version is G1*
    kirriemuir
    i think thats means its ok then.just got a rim protector not reinforced
  1. Wheel/ Tyre Limitations
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 2nd September 2011, 21:04
  2. Will a 235 tyre go onto a 7.5j wheel?
    Last Post: 11th February 2011, 20:59
  3. Alloy Wheel & Tyre
    By aaruck in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th December 2008, 19:29
