Thread: Dashboard Contents ?
    North West UK
    Default Dashboard Contents ?
    I have a 2005 2.2 SRI Vectra and I have this really annoying noise coming from the left hand side of my dashboard.
    It sounds like a marble rolling around inside the dashboard.
    Anybody any ideas as to what might have worked loose or become detatched ?
    Is there anything that is prone to causing this ?
    My initial post about this was on the suspension forum because I thought it might have been suspension related.
    I have tried all of the obvious: glove-box door/locking mechanism / I removed the ash tray thing but the noise is very obviously at the top towards the windscreen.
    All electrical items appear to be working so I can't see it being a plug off something.
    I had a 1.8 SXI before this car which made EXACTLY the same noise.
    Any ideas ?
    Regular Member silverhairedracer's Avatar
    ESSEX
    I had a similar problem with my Vec -c,discovered it was the box which held the locking wheel nuts & adaptor,worth a look.
    Don't they use a glue for the airvent, and occasionally the fixings can work free
    The Vectra B used to suffer this quite a lot, and the only solution was to remove the dashboard, replace the glue, and allow to dry for 24 hours
    North West UK
    confused
    Thanks for the answers.
    The glovebox was the first port of call when this noise started, and yes the box of wheel nuts did seem possible. But sadly it wasn't this.
    As I said my 1.8 SXI had exactly the same noise under exactly the same conditions.
    The airvent thing does seem very plausible, but the vents all still work, or at least appear to ?
  1. I can't read the thread contents
    By Johnsdutton in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2012, 18:48
  2. Dashboard strip
    By mo-mo in forum Bodywork & Interior
    Last Post: 21st October 2010, 01:32
  3. Diesel particulate filter contents.
    By shadow in forum Diesel Engine related
    Last Post: 29th September 2010, 23:47
  4. dashboard bit
    By porthy-t in forum Styling
    Last Post: 19th January 2010, 19:18
  5. Yet another guess the contents...
    By Mark The Cabby in forum General Chat
    Last Post: 5th June 2007, 22:35
