Results 1 to 10 of 18
Thread: More Air Restriction From Vauxhall
    Regular Member SRI-150's Avatar
    Jun 2007
    Cheshire
    Thumbs up More Air Restriction From Vauxhall
    hi all, dont no if this had been mentioned before bit i noticed before when washing my car, that the grill has a restricter on the left hand side and when the bonnet is shut it covers the air inlet mouth, so if you open the bonnet and have a look theres 3 cross headed screws just undo them an this black peice of plastic comes off, so now when you shut the bonnet, the air inlet should be able to get more air in, well at higher speeds anyway, another free air mod , just to let you know mines a sri cdti 150 2005
    Regular Member archerz's Avatar
    May 2007
    Teesside
    Engine : 3.0 v6 CDTI
    Mileage : 57500
    if this works then, nice one! always can do with more cooling going into the engine!
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    This has been mentioned in the past...THe theory is if we remove it, the engine will run cold and loose power. Spoons looked into this a while back.
    Feb 2006
    Wirral
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Anyone know if this restriction is on the facelift?
    Jun 2007
    Cheshire
    i dunno whether to leave it off or put it back on ??? i dunno if its on the facelift but if it isn't maybe that means its not needed so i can leave it off!
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The face lift is very different, the intake is completely blocked. The only way to open a direct path to the intake as with the pre-face lift is to get out a knife and remove a bit of plastic from behind the grill. I did this and you can't see the hole at all but it allow cold air to feed straight in.
    Wilts
    Quote Originally Posted by nutron View Post
    Cheers Nutron
    Feb 2007
    North west
    I cut away the parts of the grill with a dremmil on my 2.2 dti vec c to improve the air feed - and also some of the metal under the bonnet. No more **** in the filter box than usual. Seamed to work, it reached and passed the 150 bhp mark that I was desperate to get to as all the 1.9's were more powerful. When i replaced the grill with an Irmy one it was already fully open anyway.
    Jun 2007
    Cheshire
    well i put it back on this mornin. dont like the idea of water gettin in i know its highly unlikely but it would be a bit of a problem if it did. i dont know whether to take it off agen now lol, u guys think it makes much difference as the grill slats point up anyway? to go like up into the air feed
  1. Replies: 13
    Last Post: 7th April 2011, 15:39
  2. Removing Air Intake restriction?
    By luke4487 in forum Petrol Engine related
    Last Post: 22nd March 2011, 22:03
  3. Petition against 50 mph restriction
    By Johnsdutton in forum General Chat
    Last Post: 15th March 2009, 08:43
  4. 1.8 Air Filter max restriction?
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2008, 17:20
  5. Air Box De-Restriction on 1.9 CDTi 150
    By Maverick in forum Diesel Engine related
    Last Post: 1st February 2007, 23:16
vauxhall intake restriction
