Results 1 to 10 of 11
Thread: Had scrape to bumper repaired
    Regular Member denzo's Avatar
    Runcorn
    Default Had scrape to bumper repaired
    Had the local chipsaway guy come out this morning to remove minor scrape from front bumper.
    Was quite impressed, he sanded down, filled, sanded and then mixed his own paint to match the car and sprayed the affected area.
    Cost was £70 + VAT
    Unfortunately he left a little overspray on the plastic trim at the bottom of the front bumper .... can anyone suggest the best way of removing this overspray please
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    try a bit of meths/paint thinner. I would test it on an inconspicuous place 1st to make sure it didnt bleach the plastic
    Nicking Ya Dinner.
    Nip back to their office and point it out in a nice way and ask if they can do something with it, might need to wait a few days for the repair to harden, which is probably why he didn't want to cut compound it at the time.
    Runcorn
    Just removed 99% of it with a little paint thinners / petrol.
    The painted area is quite dull - the guy told me to leave it for 3 days or so prior to wax and polishing it .... it will come up like new.
    Still .... £70 + VAT is better than a new bumper
    I was quite impressed that he could mix his own paint from the paint code on the VIN Plate
    I'll be a little more careful with low walls in the future
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    If you have any detailing clay then this will remove over spray.
    Tyneside
    Have you got any b4 and after pics m8?
    Runcorn
    Mark
    I couldn't bring myself to take any before pics .... I had a slight glancing blow to a brick wall with the front of the bumper ...
    I'll post some after photo's when I have washed and detailed the car next week.
    Does detailing clay work on the plastic trim?
    Tyneside
    Rushy says it will, so its worth a try. Would like to see the finished article as i've got a small scrape on my bumper that needs sorting.
    Vehicle : SRi
    Mileage : 110000
    I had some over spray on the black rubber at the bottom of the rear windscreen and it did the trick on that . Paint was a couple of months though.
    SOMERSET
    If you have over spray just use quick clay and that will safely do the job.
  1. Advice needed on a repaired crack on rear bumper
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 22:09
  2. For those that have had a small ding/scrape
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 13:49
  3. On a Back bumper can tiny cracks be repaired?
    By shaun260589 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 18:43
  4. Small scrape on the Bumper
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2007, 15:19
  5. I've had a bit of a scrape love...
    By JCB in forum Comedy & Humour
    Last Post: 18th August 2005, 14:04
