Hi I've Just Got Some Irmscher Side Door Decals Same As Yours Any Advise On Putting Them On Please Also Do You Know The Part Numbers For Chrome Door Handles And Mirror Covers That Are On Your Car Thanks Dave
hi m8
wohoo your car looks the same as mine,you copying me at all
lol only kidding m8
fitting of door decals can be tricky,when you start then you have to make
sure its level with the bottom of the doors but make sure you start the
actual lettering about 10mm from the bottom of the door then start peeling
the backing a bit at a time then stick and position the lettering and make
sure you use a detailing spray and keep it wet all the time as you peel away
the backing but also you have to peel the front aswell as you go along not
forgetting to use some kind of plastic card to smooth out the air bubbles as
you go along,this operation is really a 2 person job as 1 person can control
the backing and the front as you peel it and the other person can
consentrate in making sure the decal comes off the backings properly and
also can keep it wet all the time,the more its wet the easier it is so you can
manover it easily go along the whole decal till its all stuck onto the door and
leaving it overlap were the joins between the doors,wipe and leave for a
while before you cut it were the joins are on the doors,making sure you dont
forget that its overlapping the doors just incase you open the doors
accidently then will cause the decal to stretch and break like i did in
germany,also as you go along makeing sure the air bubbles are smoothed out
but dont press too hard as it tear,its a very delacate procedure and i
struggled on me own just replacing a damaged 1 about a 3 weks ago
that i damaged back in germany.
as with the door handles and door mirrors if you drop me a pm
then i`ll price them up for you.
hope this is of any help for you
what i did was masking tape 15mm along the bottom of both doors and up the back door aswell
you have a start point and a line to follow
good luck
thank for reply looks like hard work but i'll give it a go might end up comming to you hint hint. i'll see how i get on with first one.
can i have your wheels look more like yours then heehee
pmsl yeah i wud a little wouldnt it
