Thread: Question for Andyvec
    Regular Member butcher-boy's Avatar
    Lincoln
    Default Question for Andyvec
    Hi I've Just Got Some Irmscher Side Door Decals Same As Yours Any Advise On Putting Them On Please Also Do You Know The Part Numbers For Chrome Door Handles And Mirror Covers That Are On Your Car Thanks Dave
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by butcher-boy View Post
    hi m8
    wohoo your car looks the same as mine,you copying me at all
    lol only kidding m8
    fitting of door decals can be tricky,when you start then you have to make
    sure its level with the bottom of the doors but make sure you start the
    actual lettering about 10mm from the bottom of the door then start peeling
    the backing a bit at a time then stick and position the lettering and make
    sure you use a detailing spray and keep it wet all the time as you peel away
    the backing but also you have to peel the front aswell as you go along not
    forgetting to use some kind of plastic card to smooth out the air bubbles as
    you go along,this operation is really a 2 person job as 1 person can control
    the backing and the front as you peel it and the other person can
    consentrate in making sure the decal comes off the backings properly and
    also can keep it wet all the time,the more its wet the easier it is so you can
    manover it easily go along the whole decal till its all stuck onto the door and
    leaving it overlap were the joins between the doors,wipe and leave for a
    while before you cut it were the joins are on the doors,making sure you dont
    forget that its overlapping the doors just incase you open the doors
    accidently then will cause the decal to stretch and break like i did in
    germany,also as you go along makeing sure the air bubbles are smoothed out
    but dont press too hard as it tear,its a very delacate procedure and i
    struggled on me own just replacing a damaged 1 about a 3 weks ago
    that i damaged back in germany.
    as with the door handles and door mirrors if you drop me a pm
    then i`ll price them up for you.
    hope this is of any help for you
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    what i did was masking tape 15mm along the bottom of both doors and up the back door aswell
    you have a start point and a line to follow
    good luck
    Lincoln
    thank for reply looks like hard work but i'll give it a go might end up comming to you hint hint. i'll see how i get on with first one.
    Lincoln
    pm sent
    Lincoln
    can i have your wheels look more like yours then heehee
    8 Post(s)
    Trim : elite
    Year : 2011
    pmsl yeah i wud a little wouldnt it
  1. Andyvec!!!
    By AJA in forum General Chat
    Last Post: 25th February 2007, 17:02
  2. Big Thank You to AndyVec..
    By spoons in forum General Chat
    Last Post: 23rd February 2007, 05:05
  3. Fao: Andyvec
    By AJA in forum Signature & Avatar Testing
    Last Post: 18th September 2006, 21:28
  4. Thanks to AndyVec
    By ukdesigngroup in forum Quick Photo Album
    Last Post: 8th September 2006, 23:18
  5. Wot Do You Think For Andyvec
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2006, 15:15
