Results 1 to 10 of 25
Thread: Mixing and Matching Springs.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Default Mixing and Matching Springs.
    I had my car lowered yesterday, Bilstein Shocks and Eibach Springs. Looks pretty good, however i am a little disappointed on the apparent visual lack of drop on the front end. I was toying with the idea of putting 45mm springs on the front, while retaining the 30mm on the rear. Is this possible, and more to the point, is it safe??
    Next problem though, is that it appears that Eibach dont make 45mm springs, the only others i could find would be PI one's, would it be ok/safe to have 2 different makes of springs on either end of the car??
    Help please?
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Jun 2007
    Just for you Soulman, not the best picture in the world though.....
    I am pretty happy with the rear, its just the front i'm not happy with.
    Jul 2006
    Mexico
    Yeah you right that does not look even....for some reason..
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    agreed for some reason it dont sit right..........maybe someone will be along to advise......but alot of ppl gone to billing this weekend..so mite have to be patient
    Jun 2007
    I really should have got before and after side on shots of the car, so i could compare them.... But i forgot!
    Jun 2007
    Anyone else on here got the same set up on standard wheels, so i can compare against someone else's??
    I'm wonderng if the garage that fitted them have done something stupid like putting the springs in upside down(If its possible), or they havent seated properly.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Give them a week or two to settle, then have another look.
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I put the eibachs on and used the uprated eibach shocks too. The front did seem to be higher but it setted a little more over time (not much mind). I wouldn't want the front lower, that's for sure as I caught it on the road turning a corner on a hill?!? Shouldn't be a problem as such with raising the back but it might effect handling, in that it might make the back end light.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Just a point,your car is a SRI so comes with a 15mm drop as standard so if you use 30mm drop springs you're actually only dropping 15mm,this might explain why it doesn't look a big difference.
  1. MP3 Mixing
    By Aidi in forum The 'Off Topic' room
    Last Post: 18th January 2011, 21:34
  2. Anyone else into mixing or Djing?
    By TimTay in forum General Chat
    Last Post: 27th December 2010, 20:25
  3. Mixing oil grades
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2008, 20:51
  4. Mixing Polishes.
    By FIL 4822 in forum Detailing and Car Care Discussion
    Last Post: 19th March 2008, 21:00
  5. Mixing oil?
    By grumpano in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2006, 16:13
