Results 1 to 10 of 24
Thread: Whats the difference 2.2 and 2.2 direct??
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Whats the difference 2.2 and 2.2 direct??
    Iv got a 2003 2.2 sri, now on the facelifts they are 2.2 direct, whats the direct all about and is there much difference
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The direct has about an extra 10 bhp and better MPG. Mechanically they are more or less the same.
    morton
    yeh ! alot better MPG !!
    May 2007
    Norwich
    Engine : 2.2 z22se
    Can i fit the twin exhaust system from the direct to mine?
    morton
    aslong as you get the right parts and the rear diffuser thingy it should bolt straight on matey !
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Sure can mate, The hangers are all there you just need the rear insert for the twin zorst.
    May 2007
    Norwich
    Engine : 2.2 z22se
    Ive been looking at the vxr insert,Any prices for zorst parts?
    morton
    and they made a 3.2 with twin outlets where the tail pipes were hidden ! alot cheaper than getting an SRI/GSI one ! just ahve to have two tailpipe finishes welding on , which means you can chose ones you really like and not the boggo VX ones !!
    morton
    go to the scrappys mate !!
    Ashington, Northumberland
    Quote Originally Posted by tub69er View Post
    A direct injection means that the fuel is injected straight into the cylinder, this ensures a cleaner more efficient burn therefore maximising fuel economy and increasing power. It also allows for a higher compression ratio as there is no pre-chamber/swirl chamber. The swirl is accomplished by either machining the top of the piston crown or bevelling the top of the piston crown. Swirl is important for efficient mixing of the fuel and air to maximise thermal efficiency. There, clear as mud
  1. Whats the difference
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 22:31
  2. whats the difference
    By Morephun in forum Comedy & Humour
    Last Post: 7th February 2009, 23:20
  3. Difference between 2.2 and 2.2i Direct
    By Boba Fett in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2008, 13:44
  4. whats the difference between a 2.2 and a 2.2 direct??
    By chris m in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 08:24
  5. Whats the difference? - TC & ESP
    By TonyR999 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 21:00
