As the title says... I know the Engine Control Module is, but which other modules on a 2003 build car are reflashable?
Reprogrammable as in how exactly?
My 2002 ECM had a fault code related to it to either reprogram or replace. Garage I took it to reflashed all the ecus with later software and fixed the problem but had the ecm needed replacing it gets programmed to the car & that is it, it cannot be reprogrammed for use on another car afterwards.
Duncan, I mean changing the software itself, not changing the configuration it uses. To use a Windows analogy, I mean using a Service Pack as opposed to changing the desktop background colour.
