Thread: Vectra C Doors water retention
    May 2006
    scotland
    Default Vectra C Doors water retention
    Noticed this ages ago and meant to post. Has anyone ever noticed after heavy rain, if your vectra is parked on a slope and on a camber, when you open the doors on the side that is in the lowermost position, any rainwater that has bypassed the window seal just sits inside the bottom of door cavity and does not escape until the door is opened? I have. I think this is something to do with the rubber seals on the body that mate with the door when closed. These do not appear to let water drain out the door drain holes at the bottom inner door skin. If I drive the car first though, the water must have a way out as I only ever notice this if I open the door after heavy rain and the car has not moved. Potential rust spot when the car is older I think. Thinking about cutting a channel in the rubber seals in the area of the drain holes to allow standing water to leak out. Only ever noticed when the car is parked on a slope, as it is outside my house.
    May 2006
    Mansfield
    Had this with the previous Vec b especially on the drivers door. (probably because that was sitting the lowest). Not noticed it with the Signum.
    SJ
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Yep, I have recently noticed this what with all the lovely weather we're havin.
    Cutting the rubber seems a bit excessive, think i will just open the doors a bit more often.
    Hertfordshire
    Rust "shouldn't" become a future issue, the insides of the doors are usually well and truly waxed up, just check that the drain holes in the bottom of the doors are wax free and not at all restricted.
  1. Taxi Doors / Autolocking Doors
    Last Post: 17th April 2012, 19:05
  2. Vectra C Doors
    By Dazbaz in forum Bodywork & Interior
    Last Post: 23rd March 2012, 00:20
  3. Water/Dirt Stains on seats and doors
    By adam05signum in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 15:39
  4. Number plate retention for new car
    By Gregg in forum General Chat
    Last Post: 29th January 2010, 10:59
  5. Putting a p/plate on retention
    By stec in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 18:07
are there any drain holes in the doors of my 07 vectra
