Results 1 to 10 of 15
Thread: Reduced power when low on fuel?
    Regular Member Adam's Avatar
    Dunstable, Bedfordshire
    Default Reduced power when low on fuel?
    Hi all,
    When I picked my new Vectra Elegance up yesterday, I noticed a distinct lack of power when compared to the test drive a couple of days earlier. However, the service light was on (garage couldn't turn it off - got a service certificatte from last week though), and I only had 20 miles worth of petrol left (in fact, it was redlined).
    I got home, turned the service light off using the instructions on this forum, and went to fill the car up with petrol. Since then, it seems to be fine. Back to full power and it flies like a beast. Does anyone know if the car limits revs or power when you're low on fuel or your service light is on?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Doubt it.
    No mate, it doesn't limit the power when low on fuel. It must of been your imagination matey. Enjoy the car and don't forget pics - it's the law!
    Quote Originally Posted by AJA View Post
    Nah. I definitely didn't imagine it. Even with the accelerator floored, it moved off slower than any car I've ever driven (and I've had 1 litre rustbuckets!). Basically, it felt like it was trying to pull away in 4th gear.
    Feb 2006
    Guttedsville
    Maybe the fuel tank was so low, it was trying to drink the dregs and crud in the bottom of the tank, refilling it made it float to the top so burning clean fuel.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Filtration guys......
    There will be a strainer in the tank so no crud can be picked up. And anyway crud in modern fuel systems would be EXPENSIVE
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    You sure it was the service light and not the engine management light? Sounds like you may have been in limp mode, and the reset sorted it perhaps?
    Quote Originally Posted by MysteryElite View Post
    It was the spanner inside the car, which from what I've read I think is the service light. Unless I'm wrong...?
    Feb 2007
    North Somerset
    That sounds like the engine management light. If that was on when you were driving you were in "limp home" mode which severly limits the engine and would explain what you experienced.
    Does the light come on now when you switch on the ignition? If so there is a stored fault code. Not good that the dealer let the car out in that state, but if it has all reset OK now hopefully all will be OK.
    No, it seems fine now. Reset it when I got home, then went to get petrol - no probs. Dropped brother off at work - no probs. Went out for a curry - no probs. Went to work this morning - you guessed it, no probs
    Hopefully resetting the light has sorted it. Why would it have come on?
  1. 228 Wheel power and no more fuel :(
    By nutron in forum Diesel Engine related
    Last Post: 19th October 2012, 17:29
  2. injector cleaner, fuel up grade to V power
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 22:43
  3. 2007 Vectra C CDTI 150 EML on, with reduced power
    By mcspiers in forum Engine & Drivetrain
    Last Post: 31st March 2011, 10:54
  4. Reduced fuel consumption
    By Brutus in forum Diesel Engine related
    Last Post: 2nd February 2009, 11:58
  5. **reduced**rear Spoiler **reduced**
    By ROY2593 in forum Parts for sale
    Last Post: 17th June 2007, 18:06
