Results 1 to 10 of 26
Thread: spraying with aerosols
    South London
    Default spraying with aerosols
    I am going to fit a new front wing to my daughters astra. To ensure a good fit it will be a genuine Vauxhall part and I propose to paint it myself using aerosols. These will be obtained from the Vauxhall parts department.
    Because these aerosols are only 150mL, and quite costly, I will need quite a few, therefore I am proposing to use larger size, and I hope cheaper, cans from "Halfords" for thefirst few coats.
    My question is without knowing what type of paint both types of can are filled with will there be any reaction between them once applied.
    I am also going to use large cans of primer from "Halfords" and will leave the inner surface of the wing in primer.
    Can anyone find fault with my approach or do you think it is okay.
    Comments welcome,thanks.
    Up Norf
    that will look terrible! halfords colour match are a mile out, not to mention the matt/patchy finish
    Up Norf
    ps spray cans splutter too, wouldn't paint anything bigger than a wing mirror with cans....
    Seriously mate, don't do it. You really need a good finish on a wing in my opinion. It won't be that much to have it sprayed professionally, so get a bodyshop to do it matey.
    Bristol
    What year/colour Astra is it, I'm sure you'll be able to get one from a breakers cheaper than buying a new wing and spraying it with Halfords paint.
    Up Norf
    you'd be better getting a cheap *** wing or a second hand one and having it proffessionally sprayed.
    The slight missalignement would look better than an aerosol sprayed wing!
    Tyneside
    Quote Originally Posted by armstma1 View Post
    Have to agree there not even close.
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    as above, the paint at halfrauds is not even close tried star silver and looks more like champagne lol
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    as above, stay away from halfords paints and get a bodyshop to do the work, it will defo be worth the money..........
    Midlands Mod Shop - NFFC.
    South London
    Thanks for the replies.
    I was only going to build the first few layers of the colour coat with Halfords paint to get some depth without the expense of the Vauxhall paint and then apply a couple of coats with the Vauxhall supplied cans, to give me the correct colour match. I was more worried about the mixing of two different brands of paint giving reacting with each other.
  1. Spraying
    By signumboy in forum The 'Off Topic' room
    Last Post: 22nd August 2011, 22:40
  2. how much for spraying?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 13:16
  3. spraying
    By WKD-mcc in forum Styling
    Last Post: 17th April 2009, 15:48
  4. FS: Bamboo Green (+ Lacquer) Aerosols
    By Quinten in forum Parts for sale
    Last Post: 23rd September 2008, 08:46
  5. need spraying
    By wanna veccy in forum General Chat
    Last Post: 30th April 2008, 17:05
