Results 1 to 3 of 3
Thread: tyre pressures for 1.9 sri
    Regular Member marky2027's Avatar
    Northumberland
    Default tyre pressures for 1.9 sri
    Think i might be having probs with tyres on vectra cdti sri 150 causing vibration/build up of pressure inside car (causing excessive swallowing to clear ears in the cabin) Not getting vibes through steering wheel but gonna get balancing checked at dealers. Running on Good Year Eagles 215/50/17s. Have set pressures to 32 front and rear as per manual and the trouble and strife says that it feel a bit easier. Does anyone know if there is any benefit or should i be running them at higher pressures???
    Last edited by marky2027; 3rd July 2007 at 20:25. Reason: too much lager. My PC needs a breathaliser!!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    It's a long shot but maybe you're getting a static build up in the car - try an earthing strap - provided you can still buy them of course
    Northumberland
    That sounds both interesting and technical mate. If there was a build of static would I not be getting shocks off the doors like you do off those lift call buttons in shopping centres!!
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
