Thread: sill plates removal ?
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default sill plates removal ?
    does any body know if the irmscher sill plates are able to be removed without bending or damaging them, i am assuming they are fixed by double sided sticky tape although i stand to be corrected on that. any advice would be appreciated as there is some on an o4 sri at a local scrapyard and the guy said i could have them for a tenner if i can remove them.
    cheers, graeme.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i thought they were held on by sticky pads mate, but should be able to take them off with care and a flexible blade of some sort, good luck
    Midlands Mod Shop - NFFC.
    it's trim tape that holds them, so yes, be careful and you should have a £100 saving..
    Regular Member stusdc's Avatar
    Jan 2006
    AYRSHIRE - SCOTLAND
    Take a tin of furniture polish with you, squirt as best you can under the sill plate and leave for about five minutes, the polish will eat the glue on the sticky pads making it easier to remove, (works great on stickers and the like)
    YOU MUST NOT However tell my wife that i know what a tin of furniture polish looks like!!!!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I reckon you'd get the same result with WD40 & if you use a nozzle extension tube you should be able to spray it right under the trim
    Feb 2007
    Durham
    thanks for the advice guys i will let you know how i get on.
    Feb 2007
    Durham
    went back today armed with a bottle of white spirit (to under over the plates and break down the adhesive) and two scrapers (to ease them off) only to fid that the bloke had tried to remove them for me and he had bent them, they were a mess, (plonker) never mind thought it was to good to be true me getting a bargain.
    Jan 2006
    AYRSHIRE - SCOTLAND
    Unlucky mate, keep the stuff in the boot of the car for next time tho..
    Happy hunting
  1. Sill plates II
    By Ben_ in forum Styling
    Last Post: 22nd February 2011, 14:48
  2. Sill plates
    By badback in forum Styling
    Last Post: 21st February 2011, 15:54
  3. sill plates
    By neverlandandy in forum Styling
    Last Post: 8th May 2010, 18:47
  4. Kick Plates/Sill Plates-Stainless Steel-read "VECTRA"
    Last Post: 19th November 2009, 09:46
  5. Replies: 9
    Last Post: 26th November 2007, 22:26
