Thread: Travel Assistant or not ??
    Jun 2007
    Northants
    Default Travel Assistant or not ??
    My 04 Design Signum should have come with a Travel Assistant as standard I understand.
    Well, there isn't one.
    If it had one fittedas standard, I'm led to believe there is a power socket in front of the seats?
    Can anyone be more specific?
    Dave
    [Ex]Admin Duncan's Avatar
    Have a look at the How 2 Brakebuster did (in the How 2 section) You'll see exactly the sort of socket that would be there. You can't really miss it if you have one. It's 4/5 inches wide with a flap over it and lots of pin sockets in it.
    Regular Member DesignforLife's Avatar
    Lancashire
    Thumbs up
    Someone Correct me if I am wrong:
    The Signum Elite pre F/L had them as standard & the others could option this at the dealers.
    I have retrofitted a T/A this year - after bagging a brand new Assistant on German Ebay.
    To check if your car is T/A ready - you should have a power outlet/ brackets hidden under a hinged plastic cover on the trans tunnel. This is wired to a fused power supply. The rear brackets slide into the 2 little channels on the centre seat backrest.
    As Duncan said - check the How To & Get scouring for a decent T/A - just make sure you get the right colour lid to match your interior...
    Good Luck!
    Full Member Big Sig's Avatar
    No your wrong I believe, all 04 siggys had them as standard according to the info I have
    See page 6
    http://www.vmproductforum.co.uk/serv...le-2004ed1.pdf
    Nr Cardiff
    Will have one for sale next week. Charcoal/black material, in nice condition.
    £100 plus P&P. Will be going in the for sale section unless you want to PM me!!
    Quote Originally Posted by Astrase20 View Post
    Which info would that be then?!
    Edit: Ah, you edited your post!
    They were standard on 03 Elite, standard all 04 models and an option only from 05 onwards on all models.
    £100 thats a bargin to me!
    Yep sure did D!
  1. travel assistant
    By chris in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 19:47
  2. Travel assistant ??
    By Syvlie in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2007, 07:55
  3. Travel Assistant
    By Triple Trouble in forum Parts for sale
    Last Post: 11th July 2007, 08:23
  4. Travel assistant
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2007, 08:42
