Thread: EGR valve and Swirl Valve
    Mar 2007
    Blyth
    Default EGR valve and Swirl Valve
    ok i know this has prob been asked b4, but wot the living hell is a EGR valve and Swirl Valve, and wot do they look like? (pics??) i checked my engine bay and all i see is shiny things lol, also any way of knowin if these are shot? warranty endin soon wanna get them sorted if they are shot, knowin my luck and the day the warranty ends these will **** up.
    Jul 2006
    The EGR (Exhaust Gas Recirculation) valve and the swirl valve are both to do with the inlet manifold, but i'm not sure where exactly they are. You'll know if they're shot, because the engine management light will come on.
    I've had them both done under warranty and my car is not quite 2 years old.
    HTH
    Bristol
    Vehicle : CDTI 150
    EGR, to improve emissions, exhaust gas is fed into the inlet manifold, after the turbo. This increases the temperature and improves combustion. As the fuel/air mixture needs to be accurately adjusted to take into account the exhaust gas then failure of this system causes poor performance.
    Not so sure about the swirl valve, but I think it works as follows: helps bring the fuel-air mixture to a high swirl rate at low rpm. This leads to efficient combustion and high torque. At high rpm the swirl is reduced and this in turn improves power output.
    Mar 2007
    Blyth
    thanx for that info lesj, when did cars start to become so ****** complicated?!?
  1. Swirl Valve bar has come off
    By coooky in forum Engine & Drivetrain
    Last Post: 27th January 2014, 11:57
  2. Egr valve, swirl valve problems etc..
  3. swirl valve
    By vectra_lover09 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th July 2009, 13:09
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. Swirl Valve...
    By teilo in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2008, 23:09
