Thread: hi all....corsa question??
    Apr 2006
    n ireland
    Default hi all....corsa question??
    hi lads, no probs with my sri vectra, but i got a little 2000 corsa 1.0 12v for my sister with 37k on it, everything seems dead on, until i got it home, i realised that there was no hot air blowing for internal heaters, also the temp guage was not rising very far after a 100mile journey at weekend?? barely moving at all..engine is warm, coolant is at maximum also feels warm, has my thermostat gone? or is there a switch/solenoid/ or something that operates the heater, any info would be greatly appreciated?
    if the engine is getting warm and you can feel the pipes getting hot, then it's unlikely to be the thermostat.. you can feel if it's working by the 'sudden' rush of warmer water down the inside of the pipe..the coolant sensor could have failed and be a seperate fault to the heater which could well be a stuck valve..
    Apr 2006
    n ireland
    Default cheers
    coolant sensor sounds about right!! i,ll have a nosey round that idea!! cheers
    Apr 2006
    n ireland
    Default HI
    Where would i get an engine layout picture of 2000 corsa 1.0 12v, i need to locate the water temperature guage sender unit? would this cause there to be no hot air blowing?
    no, it would just cause the temp guage to not work, and it's located on the water pump on the end of the engine with the black chain cover on it, drivers side..
    the heater problem is more likely to be water flow or the lack of it via the heater matrix, or even the flaps/ducts within the heater system
    Apr 2006
    n ireland
    Default info?
    cheers mate, is there any site? you know of or anywhere that would give me info on heater matrix etc, as i dont want anything to happen the car while my sis is driving it as i got it for her!! if its only the heater then it shoudnt be a problem until winter weather comes!!
    try corsasport.com for their input..
    Apr 2006
    n ireland
    Default ok
    i dont think the matrix is leaking or anything as there are no signs of dampness etc inside car, if it was blocked or air locked or something, would it cause this, maybe i could reverse flush the matrix? thanks for any info anyway mate, will check site tomorrow!!
    Apr 2006
    n ireland
    Default sorted
    it was the flaps/ducts, the cable clip had disconnected stopping the cable from sliding in and out of the cable sleeve, which in turn didnt operate the flap!! roasting hot hair blowing now!!
  1. A corsa question
    By purple170503 in forum The 'Off Topic' room
    Last Post: 1st October 2011, 13:29
  2. Cambelt question on a 2004 Corsa?
    By 1992 GTO in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:32
  3. Corsa D Question.
    By rushy in forum General Chat
    Last Post: 18th November 2007, 23:45
  4. Corsa B Track Car Question?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2007, 22:44
