Thread: Headlight sensor
    Regular Member butcher-boy's Avatar
    Lincoln
    Default Headlight sensor
    Hi i've got automatic lights but they seem to be always on even when sunny . Do any on know where the sensor is , i want to give it i clean to see if it solves the problem or if any one has any other ideas what the problem might be . thanks Dave
    morton
    i suppose if the sensor is obscured by something it would cause this problem ??
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by butcher-boy View Post
    the sensor is on top of the windscreen, same place as rainsensor
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Have you had the screen changed? Anumber of people have had problems with the sensor and also the rain sensor. Take it in under warranty.
    Lincoln
    yes the screen has been replaced by autoglass
    Jul 2006
    there's your answer how recently was it done? You should be able to get it sorted fairly easily.
    Here, there and every where!
    Same thing happened to my Signum after the screen was replaced. Didn't have chance to get it sorted as it was sold a couple of days later
    Why they can't replace a screen and leave everything working properly after is a mystery
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Andyvec had the same problem they had trap the cable when fitting a new screen amd the light where staying on in auto all the time
    lowestoft
    I had the same with RAC windscreens, they ran a knife around the old screen to loosen it and sliced straight through the wiring loom to the sensor and mirror. dealer had to fit a new loom that runs right round the roof lining to a plug coupler in the boot. windscreen changed dec 06, RAC agreed to pay for a repair (after many letters)feb 07, 3 days in the dealers to find the part no (cos there are 12 different looms?) then roof put back together as said loom is on back order, called to say part finally arrived a few weeks ago, now fixed!
    Do not use RAC windscreens.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. rain/headlight sensor
    By pilgrim in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 21:10
  4. Auto levelling headlight sensor
    By braby in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2010, 05:00
