Thread: Do you understand computers????
    Regular Member ROY2593's Avatar
    Caernarfon,North Wales
    Default Do you understand computers????
    Does anyone understand computers???
    My laptop does'nt read or recognise cd's/dvd's when i put them in the drive!!
    I can't play or burn any disks on the laptop, this has happened since i updated my windows xp a while back, but i can't revert back!
    Can anybody help me please ??
    Thanks in advance,
    Roy.
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    First off, a few things:-
    Has your optical DVD/CDR drive vanished from your Windows Explorer altogether?.
    As in, when you go to "My computer" can you see your "C" drive and also your DVD/CDR drive in there?.
    What happens if you look in your BIOS at your PC's startup?. Is your optical drive listed in there?.
    Depending on the above, you might want to try this:-
    http://www.dougknox.com/xp/scripts_d...cd_dvd_fix.htm
    Hope that helps.
    Jul 2006
    Mexico
    Probably you need the right set of drivers m8....
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I have a similar problem on my work pc - my CD/DVD is there & visible in my computer but doesn't recognise anything I put in it - unless!! go to 'Device Manager' select the drive properties, Volumes, Populate. I can then rocognise that disc but the problem comes back if I change discs. Strangely I have no problem accessing it through NERO ???
    Nicking Ya Dinner.
    Dump the drive in system properties, then re-boot and it should show up.
    I've managed to sort it thanks, It was a conflicting programme, I downloaded the 'One care security' from windows.
    After removing this the drives worked !!
    Thanks for your replies lads,
    Roy
  1. computers going off
    By Даниил in forum The 'Off Topic' room
    Last Post: 28th June 2012, 14:46
  2. Trip Computers On The vec
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2009, 09:40
  3. I still hate computers!
    By Scalesy in forum General Chat
    Last Post: 16th October 2008, 00:07
  4. anyone know about computers?
    By amar in forum General Chat
    Last Post: 26th April 2008, 10:29
  5. computers
    By lilangel in forum Comedy & Humour
    Last Post: 18th April 2008, 09:19
