Results 1 to 10 of 19
Thread: Windscreen wiper failure
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Default Windscreen wiper failure
    My passenger side wiper has packed in completely, driver side works ok. The assemble is quite loose on that side and can be moved slightly by hand now.
    Has this happened to anyone else? Never had this happen on a car before, makes me think that somebody has broken it intentionally.
    If it has just failed, would it be covered under warranty? Anyone know roughly what it would cost to fix, otherwise?
    Feb 2006
    Guttedsville
    We've seen this before.... Hang on a mo.
    http://forum.vectra-c.com/showthread...=wiper+linkage
    it's dead common, the wiper linkage has failed.....
    there's a 'how-2' in that section on how to change it, and the part should be no more than £55+vat.. if you don't have warranty as if you do it should be done FOC
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Ah right, no biggie then, I'll get onto Vx to get it sorted cheers
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Thumbs up
    Fixed by Vx, didn't cost me anything
    Hopefully this one is a bit stronger than the last - with all this rain we're having it's certainly got its work cut out
    if it's now got white balljoints rather than the brown one's..it's fitted with the new stronger wiper rack model..so it should last the life of the car..
    Jan 2008
    Dorset
    Default Wiper Fault
    My wiper failed at 59,000, thought it was just a loose screw so didn't worry. Then at the service 61,000 they tell me it's going to cost £307.00 to replace the unit. What a rip off, tried to reason with GM but they only offered to pay 30% which works out at £50 approx (less vat first then 30% off and + vat again!!!) It is a known fault they have apparently but would not budge on the 30%. Mine is an 05 plate just gone over the 60k, I can't beleive they are so unreasonable, I had a Lexus before this and the service was fantastic, swappped a full set of alloys out of Manufacturers warranty without blinking an eye. I will never buy Vauxhall again now just out of principle. Their loss of a good customer.
    Any advice on how to swap this part would be appreciated.
    http://www.vectra-c.com/forum/showthread.php?t=15125
    thats the how-2...if it's the linkage thats broken then it's only around £50+V..if it's the motor at fault then the parts come to £130+V...either way, very DIY freindly and should take around 1.5 hrs for your first try at it..
    Regular Member justyb's Avatar
    wigan
    yes this happened to me common fault loads of linkages on flea bay thou
    just make sure the ebay linkages are the revised design with the white balljoints..they are better sealed against the lubrication washing out..
  1. Windscreen wiper failure
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 13:52
  2. Windscreen wiper linkage failure
    By Leviathan in forum Bodywork & Interior
    Last Post: 16th November 2009, 19:02
  3. Windscreen Wiper misalignment
    By KeithB in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2009, 21:45
  4. Signum rear wiper failure
    By stryker99 in forum Bodywork & Interior
    Last Post: 11th July 2009, 18:42
finty takkie
