Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: No Sound from My PC...Any ideas.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default No Sound from My PC...Any ideas.
    I have had a problem with sound on the PC for a while now. This week it finally died.
    or So I think.
    So I fitted a new sound card (Sound Blaster).....Result.....No sound of any type. Any suggestions?
    Full Member Big Sig's Avatar
    Did you put in the same PCi slot that the old one came out of or a different one?
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    No expert, but have you downloaded the lastest driver?
    HTH
    [Ex]Admin Duncan's Avatar
    Are the devices all installed properly? i.e. is the SoundBlaster listed in the Device Manager with no yellow exclamation mark next to it?
    If that's okay, have you definitely installed all the drivers as that will then add a bunch of other bits 'n' bobs under the Sound, Video and Game Controllers section.
    Feb 2006
    Wirral
    Quote Originally Posted by Astrase20 View Post
    I went for a clean slate and chose another slot.
    Quote Originally Posted by BigP View Post
    HTH
    Yeah just checked. Is up to date.
    No exclamations.
    Working through Windows trouble shooter now. Not looking good!
    Here, there and every where!
    Silly question but you have got the speakers plugged in the right socket and they are working Just a thought
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Did you replace a sound card or did you previously use on-board sound?
    If you are using a sound card instead of on-board then a) as mentioned above you need to use the speaker outputs from the sound card and b) you will probably need to disable the on-board sound.
    Go into the BIOS settings and see if there is anything related to sound (such as on-board vs PCI)
    Feb 2006
    Wirral
    Quote Originally Posted by Caterman View Post
    Thats the easy bit.
    Quote Originally Posted by MysteryElite View Post
    Hit del on boot up to enter Bios. Not sure what the sound devices are listed as but could find anything.
    Regular Member SunnyDlite's Avatar
    Jun 2007
    Notts
    Also try headphones incase u made ur speakers go *POP*
    Plus if the soundcard isnt working properly sometimes u will get an error message about it when trying 2 play a sound in media player that theres no sound hardware installed
    then theres the little mistakes which can happen like:
    Plugged into Line IN rather than Line OUT
    Plugged into MIC rather than Line OUT
    Cables come loose from back of speakers
    A jumper from the motherboard has come off (usually the case with OB sound)
    Jun 2007
    Notts
    In BIOS its usually named AC97 Audio or something similar
    if thats enabled then itll be the primary sound controller over your soundblaster card which will disable it
    if its enabled just disable (toggle using the Page up / page down keys)
  1. No sound on my Pc..
    By macdad in forum The 'Off Topic' room
    Last Post: 9th November 2012, 22:24
  2. Very strange sound ... any ideas ??
    By Phil-W- in forum Suspension, Wheels & Brakes
    Last Post: 17th September 2010, 20:31
  3. Anyone know what this sound is?
    By ryantcb in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 11:36
  4. X-Box 360 sound
    By VauxVeteran in forum General Chat
    Last Post: 26th November 2007, 15:41
  5. 1.8 Sri MPG, sound about right?
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2007, 00:04
