Results 1 to 10 of 18
Thread: 12 Volt power point in boot
    Regular Member mic's Avatar
    Jun 2007
    Default 12 Volt power point in boot
    One of the things I miss in my car is a 12 volt power point in the boot, in my last car I found it really usefull for powering a mini fridge when going on holiday. I have a SRI hatchback and wondered if anyone has fitted a power point in the boot and if so how did they do it and was it easy. I know the some of the estates have them so hopefully it can't be to hard.
    Here, there and every where!
    Easy m8, accessory socket from Maplin £4.99 a bit of decent wire and connect to the 40A supply in the rear fusebox! Job done in less than 1/2 hour
    Jun 2007
    Is there a spare space in the rear fuse box?
    Ok Just had a look and can see a spare space, but how do I get the fuse box out to wire the socket in?
    You don't need to m8, fit the wire with a male 6.3mm end and it slots in to the spare space next to the 40A fuse
    Jun 2007
    Ok, had another look and I think I know what you mean. Will get the socket bought and try and fit it next weekend. Thanks for the help.
    You can see where i fitted mine in this thread.
    http://forum.vectra-c.com/showthread.php?t=13432
    Ashington, Northumberland
    Or in this thread. I have made the rear socket permanent live too so there are two terminals being used. HTH http://www.vectra-c.com/forum/showth...ghlight=socket
    Jun 2007
    Great those two threads will really help me.
    Quote Originally Posted by mic View Post
    Excellent. Well let us know how you get on
    Jun 2007
    Default Now Done
    Well that was easy enough! Thanks for the posts to the other threads I found it very straight foward. Did it this afternoon only took about half a hour.
  1. Boot power socket + volt meter done this afternoon with pics.
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2012, 02:00
  2. Front cigarette power point
    By skip85 in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2011, 19:30
  3. 12 Volt power point in boot what you use if for?
    By winty234 in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 10:29
  4. rear 12v power point
    By Dippy-Vx-line Red in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 21:25
  5. Rear seat power point
    By mad4stela in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2007, 15:03
Where is the fuse located for the 12 volt power socket in the boot of a vectra c
power point in boot of a car
