Thread: Problems with my 1.8 SXi.
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Default Problems with my 1.8 SXi.
    My computers really playing up here, so please excuse me if my posts are wrongin any way.
    Bought a 1.8 Sxi last week from a private sale, 52 plate, 42k Miles. £3500. got it home, did about 170 miles in it no problems, then the exhaust control light came on, car was driving really juddery, and poor, managed to get it to a garage and the diagnostic machine said it needs a new crank shaft sensor, and an induction clean.
    Two other things that might affect it, it had a new egr valve fitted at 38k, and also i hit a plastic bucket which got stuck under my car the same day the problems arrived.
    The cars now worse than ever, its like the engine is strugglin to stay running, thats if i can even get it to start. its really juddery, ive got out and had a listen to it, you can hear it from the engine right through to the end of the exhaust, the engine is jumping from below 1000 revs to one and a half, nearly stalling, not doin, nearly stalling not doing... alternately every couple of seconds. im really concerned about it, really cant see how a sensor could be causing the car to do this?
    Can anyone give any advice?
    thanks so much for your time.
    Regular Member stickshift's Avatar
    North London
    I had a Renault that had the same problem. I used clean the idle control valve and it would be ok for a few months then it would return and I would clean it again. It is actually a part that is made and used by GM I mean it is exactly the same in every detail so your engine may have the same part but I could be wrong and they don't use it any more.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The engine has many sensors on it and i the car detects a problem it usually puts itself into limp mode (just enough power to get you home or get you off the motorway), the car might have gone into this with your broken sensors.
    Jun 2007
    West Midlands
    Mileage : 68K
    thanks guys, will bear that in mind SticksShift, will mention it to the mechanic on friday. but rushy would it be so juddery and strugglle to keep running, barely start etc??
    Vehicle : SRi
    Mileage : 137000
    Its only happened to me once and to be honest I was able to drive it to dealer ok and it wasn't trying to stall. Have you checked all the simple stuff? You never know the bucket may have dinted tour zorst to a point where the gasses are struggling to get through?
    Jun 2007
    West Midlands
    Mileage : 68K
    to be honest buddie im a bit thick, any chance of a list of stuff to check?i know it woul dbe a pain but it would be a huge help for me, im ionly 19 so still new to cars but also never seen or worked on a vectra before, thanks so much in advance
    Jun 2007
    West Midlands
    Mileage : 68K
    Quick update, car now wont start at all, exhaust was puffing worse than ever, but now wont even start at all.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
